07-08-2006, 01:17 AM
Re: Pics of your ride
There is no light bar. Lights are bolted straight to the bumper. Lights flip down when hood needs to be open.
Lights are Bosch Navigator Xenon ~500? each
07-08-2006, 01:22 AM
Pics of the fender well cuts you made, please.
No cuts there
07-08-2006, 02:04 AM
Few other pictures.
07-08-2006, 02:12 AM
stock Bfgoodrich vs Mickey Thompson Baja mtz
07-08-2006, 02:25 AM
okay thanks for the info!
07-08-2006, 02:31 AM
07-08-2006, 02:33 AM
Pic
07-08-2006, 02:34 AM
one more
and another
07-08-2006, 02:35 AM
07-08-2006, 02:36 AM
07-08-2006, 02:37 AM
07-08-2006, 02:38 AM
07-08-2006, 05:00 AM
Alright, enough goofing around.  How'd you fir those 38's under there? Do you ever take it offroad and if so, where does most of the rub occur?
07-08-2006, 06:12 AM
It used to rub heavily to the front sway bar plus some serious rubbing to the frame... There was no other choise then put some right sized spacers behind the wheel or buy different rims
I have only once taken it off road with these tires and no rubbing.These tires will rub slightly to the fender when hard offroading, but not as bad as it used to... My mechanic needed to remodel both fenders to make these tires roll decently. Rubbing is not really an issue because I´m not going drive it off road much.
No more "shiny spots"
07-08-2006, 10:14 AM
That a lovely rig there.
The spacers make the wheels stick out more and that helps reduce rub inside? (excuse my ignorance)  I take it the body work gets well covered in spray with them sticking out past the wheel arches ?
Also to get those tyres fitted without mods would a 4inch lift kit do the job or would you need more?
Cheers
07-08-2006, 04:38 PM
Posted another one in the H3 wild pics forum. Barnwell Mountain "Twister"-up the middle.
07-08-2006, 04:39 PM
Another angle
07-08-2006, 04:41 PM
I know... 38" will rub. even stock tires will rub if running them to limits...
I would go with fabtech 6" lift but it is not going to fit in to my carage after that.It won?t fit in even when the rear air suspension is activated. My carage door is currently looking like **** damn roof rack bars wanted to take th e door with them,no damage to the hummer  ... I have been looking for full air suspension lift or something that I could control ride height... but wheel aligment is going to be issue.
Btw. anyone knows where to get stronger rear air suspension sensor arms or do I have to make my own? Stock ones really sucks even the 06 ones...
