07-11-2006, 11:03 AM
Computer wizards????
My new laptop is suddenly taking forever to boot up. What I mean to boot up is the Windows XP startup screen stays on now for up to four minutes, versus the less than one minute it was on when first purchased.
I have run a complete Norton Virus Scan, Adware SE, PC Spy Doctor Scans and Trojan Removal scan and no viruses, trojans or any spyware (other than the standard tracking types) were shown and removed.
What could suddenly cause this problem.
I really hate to call HP customer service since I have a hard time speaking Indian.
07-11-2006, 03:02 PM
Re: Computer wizards????
I'm not a wizard but...have you tried booting into safe mode yet and seeing if it's just as slow? You typically need to press and hold F8 as the machine is starting to get to the boot menu that allows you to choose the boot options.
These articles are hardly good tutorials but they'll explain how to boot with as little as possible enabled and then reboot with more options/drivers enabled. Keep doing this until you see where the big slowdown occurs.
http://support.microsoft.com/kb/315222/
http://support.microsoft.com/default...b;en-us;316434
This article is more of a tutorial:
http://www.pcstats.com/articleview.cfm?articleID=1643
I once had a motherboard NIC on a desktop system go bad and when network was "started" everything went to hell and the PC started crawling. The network worked well, but had lots of failures and required a lot of packet resending.
'03 pewter base H2
07-11-2006, 03:37 PM
command prompt
msconfig
go to start up tab.......
uncheck what you dont need at startup.....
Could also be your HDD is failing......spyware is a possibility but prob not if you have run spybot s&d and adaware se..................
07-11-2006, 05:59 PM
A format and clean install is a good idea every now and then, IMHO.
Black Lux H2
07-11-2006, 06:08 PM
why? There is no need to format the drive and do a clean install unless he has exhausted every other option IMHO...................
do you work for geek squad?
07-11-2006, 06:11 PM
That's BS. Care and nurturing can keep a windows box going without a reinstall for a loooong time. Of course, you have to know what you're doing.
'03 pewter base H2
07-11-2006, 06:26 PM
thank you.....
07-11-2006, 06:47 PM
Guarantee you I can reformat a machine and reimage it faster that you can figure out what the h3ll is going on with it (in some cases). I'm not saying reformat becasue the f'ing thing won't print. But for our workstations, most of the time that is the quickest solution...we are using Citrix, so really not installing any software.
doubt they pay enough to buy the gas for my H2.
Black Lux H2
07-11-2006, 06:54 PM
If f5fstop is referring to a corporate laptop, then you might have a weak argument. It sounds like his system is a personal one.
Even if it were corporate, I guarantee you can't reformat, reimage, and then have a happy user with all of his non-IT managed apps installed and configured the same way as before. Plus the added cost of having the user do all the post-reimage work and not getting any other work done in the mean time is way steeper than most IT staffers ever seem to appreciate.
'03 pewter base H2
07-11-2006, 07:09 PM
That's the beauty of Citrix, no software is installed on the local machine. It's all housed and run from a server farm. Now that is a bit off subject and I realize his laptop is probably not a corporate machine. I don't regularly format my personal computers either, but was humbly offering my opinion that that sometimes is a good idea. Frankly I don't care if you agree or disagree.
Black Lux H2
07-11-2006, 07:10 PM
'03 pewter base H2
07-11-2006, 10:06 PM
Is this your new Compaq? If so, check to see what sort of pre-installed software came with it. When I got mine, I immediately wiped and started w/a fresh install from the re-image disks. I didn't install all the 'add-ons' and that helped a lot.
Follow the other instructions as indicated here on eliminating startup apps. If you've done both (re-image and removal of all non-essential startup apps), you'll likely have to deal with it - more memory or HD won't likely help much on faster startup (defrag regularly if you edit files a lot).
I've got a ton of essential software running on mine at startup, so now I never shut it down - I have it hibernate, which kicks it right back up - takes no more than 1 minute to re-start in the same place as I left when shutting it off. If your laptop is like mine, you should be able to set up the 'power' button to actually be the hibernate button.
07-11-2006, 11:55 PM
Could be a virus/adware/spyware too. Run a scan to be safe.
07-12-2006, 12:39 AM
Make sure you have only 1 virus program installed. What was the last thing you installed before it started running slow? Does it slow down when only when its not plugged into the wall? Some laptops have settings that slow the processor down when not plugged in. PM me and I can give you a call and walk through checking a few things to see whats up.
As for reformatting the HDD, thats fine for a corporate peon with a standard image. On a personal PC, it would take many hours to reload all the crap, and you would probably reload the same program that was causing the problem in the first place. Once you graduated from the help desk you may learn that someday.
07-12-2006, 01:06 AM
f5fstop,
If it's before you get to log in, i.e. before windows has started where you have, then I'm convinced is drivers that are having trouble being started and not just adware or anything like that. Most of the recommendations to uninstall things, and to disable startup services are only really going to be effective if the problematic applications are ones that get started after the windows shell starts and the user is given an opportunity to log in.
'03 pewter base H2
07-12-2006, 04:02 AM
Check your Event Logs.
07-12-2006, 05:02 AM
what if they have half-chewed peanuts in them?
07-12-2006, 05:14 AM
