07-19-2006, 04:36 AM
Toyo Open Country M/T 37/13.5/17 Tires
Just got my new skins put on..................
07-19-2006, 04:37 AM
Re: Toyo Open Country M/T 37/13.5/17 Tires
I have only had minor rubbing at the full extension of turning.............
07-19-2006, 04:41 AM
They are slightly louder than the BFG but not bad.
07-19-2006, 06:21 AM
I Love mine!
Congrats, looks good.
MINE - 2006 H2 SUT
07-19-2006, 12:21 PM
Kram looks great. I love the way those tires look on stock rims.
Do you have Air suspension? If so the air bag height sensor connecting rod is at risk when you go through ditches. I have a fix if your interested.
07-19-2006, 04:31 PM
I'd appreciate that info. Thanks!
-Pete
07-19-2006, 05:03 PM
No problems yet............... but haven't done any major off-roading, just toying around. How easy is the "fix", I might do it just in case...............
07-19-2006, 05:04 PM
PS I do have the air suspension..................
07-20-2006, 09:48 PM
When I fixed mine they were both broken. On e ditch took out both sides, I had previously only broken the driver side. The connector rod is held in place by a rubber gromet with a hard plastic pin in the center. I cut of the hard plastic pin flush with the rubber gromet. Moved the connecting rod to the inside of the sensor and drilled a small hole down the center. I did this in the field, with the truck rear end raised as high as it will go. You can still adjust the height by moving the sensor level manually. I then inserted a # 6 sheet metal screw through the sensor arm and into the rubber gromet. I did this 6 months ago so its all a little foggy. No problems since the repair. Good luck I'll try to get some pics. and post.
08-22-2006, 12:53 AM
Hey dr, have you had a chance to take pics yet of her sensor mod?
'03 H2
08-25-2006, 08:24 PM
X2
