07-20-2006, 12:21 AM
Weird noise in cargo area
Just started this afternoon. Sounds kinda like rubber on rubber or rubber on plastic. Usually only when I brake hard or go over a bump.
07-20-2006, 12:43 AM
Re: Weird noise in cargo area
Luggage area, or could it be from one of the rear doors? I had the Styrofoam type squeaking on my Utah trip over rough roads.
07-20-2006, 12:44 AM
07-20-2006, 12:51 AM
Originally Posted by HummBebe
Are you asking if the noise has an odor?
07-20-2006, 01:08 AM
I thought you said nose....sorry
07-20-2006, 01:19 AM
check that spare tire is tight and check jack compartment . if nothing found crank the tunes
did you have sex in the back ?  you probably busted the suspension
07-20-2006, 01:30 AM
Not likely, I think he's on a dry spell
07-20-2006, 03:26 AM
Crank the tunes??? Sounds familiar.
07-20-2006, 04:30 AM
ohhhh, that's cold...
07-20-2006, 05:26 AM
Put the mother-in-law on the roof!!
07-20-2006, 05:35 AM
07-20-2006, 05:57 AM
Originally Posted by Sewie
...Sounds kinda like rubber on rubber or rubber on plastic. Usually only when I am hard or go over a hump.
I know what rubber on rubber on plastic sounds like, but not rubber on rubber on rubber on plastic. Sorry I couldn't help!
07-20-2006, 05:59 AM
07-20-2006, 06:00 AM
Such dirty minds on this forum.
07-20-2006, 06:35 AM
07-20-2006, 06:53 AM
someone rubbed some rubbers and now there's an odor??
07-20-2006, 06:58 AM
rubbery smelling noise?
S.
07-20-2006, 07:00 AM
Well you guys obviously aren't any help.
I'm going to the dealership tomorrow anyways. Maybe they can figure it out.
07-20-2006, 07:04 AM
I know I know.
I have the same thing.
It is rubber on plastic.
Check the side compartment in the back on the PSSD. Tose two little rubber things on top that hold the door closed. Tighten them up. Do the same on the compartment foor to where your jack is.
It worked for ours.
07-20-2006, 05:33 PM
Well I just dropped it off at the dealership. I'll let you guys know what they find.
F5 and Timgco, thanks for the ideas.
