Old 07-22-2006, 01:46 AM
fw888's Avatar
fw888 fw888 is offline
Default under what kind of condition to lock the rear differential?
On the adventure H3, what is the rule of thumb to use that feature ??
Old 07-22-2006, 01:54 AM
humma_H3's Avatar
humma_H3 humma_H3 is offline
humma_H3 is on a distinguished road
Default Re: under what kind of condition to lock the rear differential?
any questions?
matt
cincy
matt
cincy,oh
LOCKERS RULE!! Open Diffs DROOL!!!
2006 Black Hummer H3
Old 07-22-2006, 02:16 AM
Old 07-22-2006, 03:20 AM
fourfourto's Avatar
Anytime I use 4 low
Old 07-22-2006, 03:47 AM
fw888's Avatar
Thumbs up Re: under what kind of condition to lock the rear differential?
thanks dude, it is a hell of a climb...
Old 07-22-2006, 03:52 AM
i leave mine unlocked most of the time , after a while you get to know when you will need it . just try getting up the obstacle without rear locked , if you start to get some wheel spin push the locker button , truck will usually crawl right up . the next step if still having trouble is BTM , apply the brakes while giving it gas slowly let up on brake till truck starts moving keep that tension on your brake until clearing the obstacle let off brake and unlock rear till next obstacle . leaving the rear locked for long periods can build up heat . think of it as a "use as needed" feature we dont recommend doing this without one
Old 07-22-2006, 03:54 AM
and really need it when 3 wheelin
Old 07-22-2006, 04:40 AM
Viet Nam Vette's Avatar
Holy ****...!!!
Old 07-22-2006, 05:29 AM
fw888's Avatar
thanks for the info..are all the H3 going up there ok, look like it is more than a 45 degree angle going up..wonder how is look like when going down..
Old 07-22-2006, 05:37 AM
beebster and i are the only h3's and the 2's we were with are Moab veterans . the truck will do alot more than advertised but dont feel inviencabel we both had front diff failures on our last day but we broke them on an obstacle that busts tons of rigs H1 had busted a axle the day before and it can eat up h2 tie-rods . if your on bigass slick rock just crawl if you try hittin stuff hard and spinnin wheels things can bust
Heres the view down , beebster and i are the first private owners to take our threes up lions back and thats our story !!!!!!!!!!!!!!!!!!!!!!!!! and we are stickin to it !!!!!!!!!!!!!!
Old 07-22-2006, 02:30 PM
You Guys Got Some Concrete Freaken .."GoNads....!!!!
Well Done..!!
Old 07-22-2006, 03:13 PM
deserth3's Avatar
deserth3 deserth3 is offline
Well Done..!!
Yeah; that's a long way to drive with your eyes closed!!
Old 07-22-2006, 08:23 PM
it sure is man you should try to make it over next month
Old 07-24-2006, 03:16 AM
GotSandH3's Avatar
GotSandH3 GotSandH3 is offline
GotSandH3 is off the scale
Where you guys in 4Lo and 1st gear going up and down?? Using bakes down??
Mercedes-benz Technician
Old 07-24-2006, 03:36 AM
fw888's Avatar
also when you guy going downhill, are u using the handbrake ? or just the locker..
Old 07-24-2006, 04:10 AM
just use the foot brake ( regular brakes ) for BTM and going down . put shifter in 1st for going down and you hardly need to use the brakes . i used my brakes only 3 or 4 times coming down lions 1st is really low . dont really need the locker for going down , but have heard it helps slow you even more , i cant tell a difference .
