Old 07-27-2006, 04:22 AM
Lucifer's Avatar
Lucifer Lucifer is offline
Lucifer is off the scale
Default AVIC-Z1 install woes
Spent 8 hours installing a Z1 to only run into a problem at the end Tapped the brown wire in the drivers pillar for the reverse wire. Got lucky and the VSS wire was in my radio harness Used a Metra GMOS04 wire harness because it has the Onstar and chimes built into 1 unit and you can control the volume of the chimes, (turned way down). Also had to loop the 2 purple wires in the gm harness. Only problem now is that when the key is in accessory mode, I don't hear any music from the stereo, but Onstar still works. As soon as I open the door and the door chime starts ringing, the music from the stereo comes through. As soon as I shut the door, no more music. With the key turned to on, I don't get anything even with the door opened, but again Onstar still works. I'm going to call Metra in the morning, but was just curios if anyone has any ideas on this. Checked wiring 4 times, and all seems correct. Pretty strange if you ask me.
Old 07-27-2006, 05:34 AM
Default Re: AVIC-Z1 install woes
....wait........what?????
Old 07-27-2006, 05:39 AM
freaky man F5 ?
Old 07-27-2006, 05:53 AM
Ugh! Sounds like a hassle. You should just trade me your avic-z1 for my fully functional and working n2 w/adapters and harnesses, it will really be less of a headache for you.
Old 07-27-2006, 06:59 AM
Bully13's Avatar
Bully13 Bully13 is offline
DON'T CUT THE BLUE WIRE!!! wait... or is it the red!? WE'ER DOOMED!
Old 07-27-2006, 11:06 AM
If you previously had XM, there would be three purple wires to jump over; not two. Reason for the splicing of the wires is that the serial data link comes into the radio and then is supplied to Onstar and XM via the radio link. The Pioneer head unit does not pass this link through. There should be two purple in the 24-pin and 1 purple in the 12-pin. If you don't have factory XM, no problem.
Leave the factory XM if installed connected to power.
Did the adapter come with a relay setup that had to be wired for ignition on signal? I would have to confirm by looking at some schematics, but it sounds like the there is an incorrect wire connected and I don't have a schematic for the adapter you are using.
It is also very early...
Old 07-27-2006, 12:23 PM
When you say 'looped' the two purple wires, you did leave them connected to the connector as well, and connected a wire between the two purple wires.
Mute output wire from the radio, you did connect that to the cut brown wire that goes to terminal 18 of the PAC adapter? Not sure what would happen if connected to the other terminal of the cut wire.
Red from radio is connected to pin 30 of the relay? This gives you the ignition On input that is normally supplied by the BCM to the factory radio.
Need coffe to think....
Old 07-27-2006, 12:50 PM
Spee signal, Dark Green/white it was in terminal E of the small connector that attaches to the radio?
There are a couple dark green/white wires...
Old 07-27-2006, 01:03 PM
If you turn on your headlights, does the radio operate? I'm going to be curious as to what Metra says about this. I'm installing one next week myself, using the Peripheral adapters .
Old 07-27-2006, 02:28 PM
Did you reset the Z1 after install??
Old 07-27-2006, 02:49 PM
I give up, without the wiring schematic for the Metra adapters, which I can't find online anywhere, it is hard to determine how it connects.
Old 07-27-2006, 02:57 PM
and i was happy to just add a set of 35's good luck with the gadgets
Old 07-27-2006, 03:23 PM
hmrlvr's Avatar
hmrlvr hmrlvr is offline
do you just sit back and laugh at us with our STUFF??
WWW.BCBI.COM
Old 07-27-2006, 07:29 PM
Lucifer's Avatar
No XM, spliced the 2 purple wires in pin 24. Without the splice, Onstar wasn't working, and the 12v ignition wire wasn't hot.
Old 07-27-2006, 07:35 PM
Lucifer's Avatar
I just installed a double wire splice in between them.
Left the mute wire from radio disconnected, do I need to splice this in??
Yep, getting power just fine now, nav works but no sound.
Yes need more coffee.....coffee is good....
Old 07-27-2006, 07:36 PM
Lucifer's Avatar
Without XM, I only had 1 green/white wire, sure was happy when it worked.
Old 07-27-2006, 07:50 PM
BuzzH3's Avatar
BuzzH3 BuzzH3 is offline
BuzzH3 is off the scale
Did you have the Monsoon system? If so, it sounds like the amp turnon is not connected or connected to the wrong place. Make sure that you have the remote amp lead from the Z1 connected to the amp turnon lead from the harness.
2006 H3 Black Luxury package; Off-Road package; Sunroof; AVIC-Z1/Monsoon; XMNavTraffic; iPod adapter; Rear view camera; Front bumper letters; Splash guards; Mudder floor mats; UC Protection
Old 07-27-2006, 07:51 PM
Lucifer's Avatar
In accessory, radio plays with lights as long as door is open. Once door is shut, it looks like it should be playing with lights on. Don't know if this helps much.
Old 07-27-2006, 07:55 PM
Lucifer's Avatar
Yep, no help.
Ya, I couldn't find a wirning schematic for it either, just going to call Metra.
Old 07-27-2006, 08:36 PM
Lucifer's Avatar
DOHHHHHH!!!
The label on the z1 was labeled system connect, didn't think the amp power was connected to it. Everything works fine now. At least I didn't have to call Metra tech support, hate tech support.
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
now I just have to go find one of those silly antenna adapters...
