Old 07-27-2006, 11:55 PM
working Hummer's Avatar
Default Piaa lights?
Hey, getting a couple of Piaa lights for front grill on my brush guard, what series is the best for that spot 510 or 520 and what bulb is the best to get just for a driving light when going down country roads? The Piaa sight is confusing on this so help and opinions would be appreciated. thanks and good will to all. Oh by the way my "Hybred Synergy Drive" sign/stickers I stuck on the H2 are hilarious. I'm even snickering right now thinking about it.
Old 07-28-2006, 12:08 AM
Default Re: Piaa lights?
520 SMRs on the grill guard
http://www.elcovaforums.com/forums/a...5&d=1153332271
Old 07-28-2006, 12:28 AM
Originally Posted by PARAGON
Now I don't have that cross bar you have yours mounted to. Will the lights bolt on to the grill guard where there are holes already? I'm only getting two of them.
Old 07-28-2006, 12:41 AM
Umm.... ya know. I can't answer that for sure. But the stock lights aren't very small, so I would have to guess that the 520s would easily fit.
Old 07-28-2006, 12:57 AM
thanks Paragon
Old 07-28-2006, 01:34 AM
ree's Avatar
ree ree is offline
I'm not sure if your intentionally only considering the 510 and 520 or not. If not, I love my 580's. They're bigger, but they match the size of the headlights nicely. Plus they're very bright. Of course, they're probably more expensive. And I don't like the grids in the other models either.
If you go this route, get the driving lights. They're not to wide an angle and not too narrow. Aim them a little higher than your low beams. They're bright enough that if they're on, then you flip on your high beams you barely notice the high beams coming on.
I mounted mine on a Warn light bar. I'm not sure that they'll mount on the existing holes, but I think they'll fit. I included both front and side views of mine so you can see how they relate to the size of a double brushguard. They're rounded enough on the back that I bet they'll tuck between the lower and upper bars on the guard. The only issue I imagine would be bolt length, whether they'll reach through the brushguard bar (I don't know if you have holes in your bar or a clamp/tab). If that's a problem you could probably make some mounting tabs that would work.
'03 pewter base H2
Old 07-28-2006, 02:53 AM
wilfred wilfred is offline
wilfred is off the scale
I believe you will need 2 of these brackets (attached pic) i dont think they sell them separately but the complete light kit part no. is 89006860.
I have a pair of these bracket sitting somewhere in the garage I will be happy to sell you
Old 07-28-2006, 11:50 PM
thanks for all your answers, they were all helpful and I would love to buy your brackets but I am going to the stealership first to see if I can buy them seperate so I don't have to monkey with shipping and all that crap. But see if you can find those brackets because I'm sure after hearing the price they want for them at the stealership I'll crap my pants where I stand so I'll get back to you, thanks.
Old 07-29-2006, 04:22 PM
Hey Wilfred did you happen to find those 2 brackets? I'm interested.
Old 07-29-2006, 08:36 PM
Originally Posted by PhilD
I like 580's, think they set the vehicle off nicely, but 520's are a good unit too, the SMR ones are more useful for most peoiple than the regular crystal ion (yellow light) ones.
[IMG]http://www.*******club.com/forum/files/piaa_black_244.jpg[/IMG]
By the way Phil awesome looking truck, did you mount the grill lights on those brackets I need or just drill a hole through the guard pipe? I ordered the 520 smr's.
Old 07-29-2006, 09:35 PM
if you don't get something worked out on the light brackets, I have a couple either out in the shop or down in a barn, still have the stock Hummer fogs attached to them I'm sure.
Old 07-29-2006, 11:13 PM
thanks PARAGON i'll let you know.
Old 07-30-2006, 09:48 AM
Yes, i found them. How bout $40 including shipping to South Dakota sounds to you?
Old 07-30-2006, 07:54 PM
Do those triangular looking brackets just bolt onto my brush guard and the lights to them? If they are the right ones and you can get them here by Thursday you got yourself a deal I will PM you with address and let me know were to send check. Thanks.
Old 07-30-2006, 08:12 PM
Yes, they each have two tiny bolts that hold them and a large hole on top to bolt the light to.
Old 07-30-2006, 08:39 PM
Check your PM for payment instruction
Old 07-30-2006, 11:33 PM
Payment sent.
Old 07-31-2006, 09:03 AM
Positive Feedback: smooth transaction, fast payment, A+++
