Old 07-25-2006, 04:56 AM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
Default Re: Prototype UCP
Originally Posted by HIHUMMER
the frame is made of 1.5" square tubing that is an 1/8" thick. But sshh....don't tell anyone.
Just an fyi on that tubing. I have the exact same thing for my roof rack crossbars. The spread between supports across the rails is ~47". The bottom of the crossrail sits ~3/8" off the top of the roof. With me standing on the rack, jumping on the rails, they won't deflect to hit the roof, but they do deflect, up to about 1/4". They also have center rails running front to back, and so truly aren't even a full open spread.
My point? You may have issues with deflection when you come down on a rock. I'm sure the combination of 1/4" plate + the tubing will be beefy, but you might want to jack the truck up using the plate and maybe a small piece of tubing to localize the lift point (just be careful, you might even be able to find the true weight center and jack the whole truck up off the ground!). See if the plate deflects, because you don't want to find it's not beefy enough on the trail .
Old 07-26-2006, 01:38 PM
HIHUMMER's Avatar
HIHUMMER HIHUMMER is offline
Thanks evldave...I might be PMing you if I come across any issues.
Old 07-30-2006, 07:56 PM
HIHUMMER's Avatar
Ok...so...what'ca think?
Pretty flush w/ the crossmembers.
Kinda difficult to tell, but there is about 2 inches between the transfer case and the metal.
Old 07-30-2006, 07:57 PM
HIHUMMER's Avatar
I am a little concerned about the bolt heads, but we will just have to wait and see how they hold up in Tellico.
Old 07-30-2006, 08:40 PM
evldave's Avatar
Looks great! Paint it bright yellow and let us know how it works at Tellico!
Old 07-30-2006, 09:48 PM
Ipedog's Avatar
Ipedog Ipedog is offline
Thats a sweet setup HI!
You should be able to slide right over anything you can't clear. The exposed heads worry me a wee bit too, but it's just a wee, small worry
Rob (Ipedog - Say "Ip-E-Dog")
Black Sheep HUMMER Squadron
Old 07-31-2006, 02:05 PM
Lookin good, can't wait to see it in action this weekend
We will just make sure to spot you so the rocks you have to slide over go in-between the bolt head
