Old 08-02-2006, 04:28 PM
Screeper's Avatar
Screeper Screeper is offline
Screeper is an unknown quantity at this point
Default Re: Supercharge or gear swap?
Thanks for the info. That puts me 200 RPM over factory with 38 inch tires which is exactly what I was looking for. I think alot of people will be at the Hummer dealer with their old trucks the second they come out with a diesel/allison truck. I know I will.
Old 08-02-2006, 07:09 PM
mowdoc mowdoc is offline
mowdoc is on a distinguished road
I know your right. Maybe we can ride together.
mowdoc
2006 H2 Adventurer loaded named "Wolfey Boy" - Pewter Silver/Wheat - Denali wood dash panels - SIR-GM1 Sirius
Wifey's ride is a 2007 Corvette 3LT F55 A6 named "Lucy"
2001 Jeep TJ with heavy mods is my off-roader - the Hummer stays clean
Old 08-03-2006, 01:22 AM
ASTAR's Avatar
ASTAR ASTAR is offline
ASTAR is on a distinguished road
Originally Posted by mowdoc
It would sure be nice to drive up a grade and keep the damn converter locked. I love my H2 but GM needs to take a closer look at shift points and downshift requests on this rig. I was spoiled by a maxed out DuraMax diesel before the Hummer and I tow a lot. The D-Max would pull a hitch in half in 5th gear while this Hummer can't pull itself up a slight grade without downshifting. Like I said, I was spoiled by the diesel. I do love the Hummer, I just wish it would stay in high gear more.
mowdoc
AMEN!
I was spoiled by my Dodge CTD the same way
MINE - 2006 H2 SUT
Old 08-03-2006, 03:27 AM
I personally would go for the supercharger. After I did my lift, I installed 4.56's. My gas mileage picked back up because the truck didn't have to work so hard to lug all that truck around.
Though it helped, at 70 mph, a minor incline will cause the truck to go into OD. I personally can't stand the performance at highway speeds with the gears... God forbid I'm pulling my enclosed trailer.
At some point I'm going to install a supercharger but that's my suggestion.
HTH's,
Mark
Old 08-04-2006, 01:30 AM
ASTAR's Avatar
Mark
I concur, I just would rather wait till the warranty is up. Even then, the gears will help other components (tranny) live a better life.
MINE - 2006 H2 SUT
Old 08-04-2006, 03:07 PM
kdio kdio is offline
kdio is off the scale
If you are pulling a trailer I would not recommend the 4.88 gears. The pinion gear gets very small on the 4.88 and it will break. When I changed gears the installer told me not to go larger than 4.56. I am running 37 inch tires and changed my gears to 4.56 and it made a big difference. I also have a super charger. I would recommend doing both.
Old 08-04-2006, 06:59 PM
Big Z Big Z is offline
Ya Just Can't make a SMALL BLOCK perform like a BIG BLOCK!, Diesel!, Or 1 Ton..(Ya Get Spoiled!---I DID Anyway)....I've Had the D-Max dually, Cummins 24v Dodge Dually, GMC Dually w/6.5L...and a few Gassers along the way! (worked THEM Hard!) And, As I'll ALWAYS Have a GOOD Work/Tow Rig....CUZ My 2 JUST WON'T DO! (Said my piece on the towing abilites of the H2 through the years...Any other comment is best left for the search link.......Nuff Said! )
Got A Whapping 15K (bought New) on the 02 CC Silverado LB, 8.1L w/Allison...A...Get-er-Done!....Pick-up. ....Just For That Reason!
Anyway, JMO, Get what you can with the programmer, back off the pedal, and enjoy your ride!-----Of ALL The Cruise Controls, (in ALL the rigs I've had anyway), The 2's...ARE BY FAR THE MOST RESPONSIVE!...It's programmed to Maintain SET SPEED--No Matter What!....And as you keep track of it, and allow it to work!....You Will Find...IT WORKS VERY WELL! No Choice! ;-)......ALL The way to 2nd, huffin hard in the hills, I think I Can, I think I can...30mph!.....NOT!...WELL!
Old 08-04-2006, 08:24 PM
So, Z, what's your take on the H2 as a tow rig?
If we pulled more, would dump the F250 Powerstroke, get the Sierra 2500 Duramax and figure out a way to put the H2's airbag-type system (from Firestone) on it.
The F250 is just too rough up front and the 2500 is rough out back unloaded.
I can't wait to see the new Sierra's built on the new 900 platform due out by the end of the year.
