Old 08-09-2006, 04:37 AM
tomp's Avatar
tomp tomp is offline
Default Will ski/snowboard mounts work with High Lift Jack?
I don't see why this wouldn't work. The appear to have rubber/foam that will take the shape of whatever you put in them.
Old 08-09-2006, 04:47 AM
Default Re: Will ski/snowboard mounts work with High Lift Jack?
Great way to kill someone. Bad idea! No (scratch that) very fckin dumb idea!!!!!!!!!!!!! May as well take a rubberband, chewing gum, and attach it to your factory cross bars.
Old 08-09-2006, 04:56 AM
H2Finally's Avatar
What my bro Tim meant was, the ski mounts are made of (kindda) flimsy alu with (kindda) flimsy rubber tubes, while the hi-lift are made of solid cast iron weighing prob 5 or 10x.
If you don't mind the look and functionaility of the hi-lift on your roof crossbars, you can prob get big screws long enough to accomodate a solid rubber block (truck bed tie or cut-out mallet), the hi-lift, and a good-sized wing-nut, and some solid washers big enough to be retained by the crossbar channel.
Can BLING Get You Home?
Old 08-09-2006, 05:06 AM
Tomp, I'm sure this was joke! Tell me you were! Please! DO NOW!
THere are pleanty other options out there. KenP has a nice/ clean way to set this up! It's a simple way to atach it too. If you don't have a tire back there, it's even easier.
Here's another link too: http://www.elcovaforums.com/forums/s...=highlift+jack
Old 08-09-2006, 07:29 AM
I fully agree with Tim & Finally. Don't be cheap when it comes to an heavy and potentially deadly item like a high lift jack. Shell out the few extra dollars to secure your jack properly.
Old 08-09-2006, 07:35 AM
Gobi makes a hi lift mounting kit, don't they?
Plus, I'd go with a lock. $22.50
http://www.central4wd.com/inventoryd...;folder%7C5620
Old 08-09-2006, 12:29 PM
tomp's Avatar
After looking at the cheap mounts on these things, I have to agree with you guys! Looks like they are plastic.
