Old 08-12-2006, 09:27 PM
Default My backup camera
Here are some pictures of the PepBoys back up camera and monitor ($99). I added NdBFe magnets to the base of the monitor and to the underneath the removable dash trim piece using double sided table. The monitor can be easily moved (just held in place by the permanent magnets) to clean the windshield. The cable with slack was run between the windshield and the dash down to the firewall connector. The camera was mounted to the right of the hitch using a homemade Al bracket painted black (there is a hole in the hitch already underneath the sticker). The camera sits inside this "cove" so water doesn't drip down on it from the bumper. The system can be manually turned on by a button on the monitor and automatically turns on when you put the tranny in reverse. I can see about one foot behind the bumper out and the spare doesn't block the view.
Old 08-12-2006, 11:50 PM
fourfourto's Avatar
Default Re: My backup camera
Cant beat that setup for that price.
I played with one at pep boys it looks like a nice setup
Old 08-13-2006, 02:41 AM
Nice affordable camera set up. A lot cheaper than my $1100 (dealer installed) Hitchcam.
Rear cameras make a lot of sense on the H3, and other SUV's too. They pay for themselves real fast, based on discussion on this forum about expensive actual backing up crashes.
S.
Old 08-13-2006, 02:55 AM
fw888's Avatar
fw888 fw888 is offline
Nice, how do you hook up the power source?
06 H3 Boulder gray,
Adv. Pack, Chrome Pack, Chrome Step Assist, Chrome fuel cover, Chrome Hood with handle, Chrome air intake, Chrome side marker light, Oem Brushguard, Tow Package, Factory Mudflaps Front/Back, XM Radio, OnStar ... more to come
Old 08-13-2006, 03:09 AM
Monitor cable went through firewall grommet near parking brake. I got +12 volts from fusebox in front of battery. I used the firewall ground. I tapped into the reverse wire from the trailer wiring connector behind the battery.
Old 08-15-2006, 02:13 AM
Black-H3-in-PA Black-H3-in-PA is offline
Black-H3-in-PA is on a distinguished road
Very nice. I had to go out and buy one before my wife backs into someone One question. I can't seem to find the reverse trailer wire behind the battery. Do you have a picture of where the wire is connected? Thanks!
Old 08-15-2006, 05:54 PM
DWPC DWPC is offline
DWPC is an unknown quantity at this point
Look's like a deal. How's the video quality? Can you post a picture of the image?
'06 H3 Adventure (9/2005-1/2013)
Old 08-16-2006, 11:42 PM
Here is a picture of the connector. It is right behind the battery. I tied into the light green wire at the bottom of the connector (the portion that goes back to the hitch becuase it has more slick to work with. I removed some of the insulation and soldered to the wire versus using a splice connector.
Old 08-16-2006, 11:52 PM
Here is is picture of the screen. The picture didn't turn out well; the monitor has much better resolution than this. No problem seeing the picture in bright sunlight. There are two bricks shown in the monitor picture. Here are two pictures from either side in the rear to show you where the bricks are. The center brick is about 1 foot behind a back of the spare. I can adjust how close I can see to the rear by bending the homemade bracket.
Old 08-17-2006, 02:21 AM
great pics, good job..
Old 08-17-2006, 04:11 PM
Boar-Ral Boar-Ral is offline
Boar-Ral is an unknown quantity at this point
S.
Tell me about it. I owned my H2 for five days before I backed into an Audi. No damage to the Hummer, but the Audi was written off due to the damage.
Old 08-17-2006, 04:23 PM
fourfourto's Avatar
I dont see a picture of the screen only 2 pics of side view of the bricks.
Old 08-17-2006, 09:09 PM
My mistake. Here it is.
Old 08-17-2006, 10:23 PM
Thanks!!
Old 08-17-2006, 11:32 PM
jp's-h3 jp's-h3 is offline
I was going to buy one off of ebay!
Time to head to pepboy's!
