08-13-2006, 06:08 PM
Air Cleaner?
Hey all,
I was trying to remove my air cleaner cover the other day, but couldn't seem to get it off. Is there a special trick to removing the cover.
08-13-2006, 09:56 PM
Re: Air Cleaner?
Originally Posted by PhilD
Two screws, one either side and it should just pull off.
Did that.....still can't get it
08-13-2006, 10:13 PM
Re: Air Cleaner?
Pull harder. Mine was "stuck" down the first time I removed it.
08-13-2006, 11:52 PM
Re: Air Cleaner?
This trucks have air cleaners?
Where?
Thhe only one I know of is the inside air purification filter under the drsd dash. But that things electronic with the bipass tube that keeps all the crap outside the truck.
08-14-2006, 12:32 AM
Re: Air Cleaner?
i tried to pull mine off today also, but could't unless i really twisted and yanked. Didn't feel like taking the bracket off that was above it and blocking it from coming off.
08-14-2006, 01:49 AM
Re: Air Cleaner?
Two screws, one either side and it should just pull off. Also I unscrew the screws that are on the windshild water reservoir, it makes it a little easier to get the air cleaner lid off and out.
You may have to pry up a little on the lid to get it to come off.
08-14-2006, 03:28 AM
Re: Air Cleaner?
I had trouble getting mine back on with a good seal until loosened that bracket above it. I think some assemblies must be wedged in tighter like mine, it was a bitc to get back on.
Dwight: Second Life is not a game. It is a multi-user, virtual environment. It doesn't have points or scores. It doesn't have winners or losers.
Jim: Oh, it has losers.
08-14-2006, 03:29 AM
Re: Air Cleaner?
Hey, thanks.....I knew there had to be some trick to it....thanks alot, I'll give it a try tomorrow.
08-14-2006, 03:31 AM
Re: Air Cleaner?
So, looks like I'll have to work getting it off and back on. Great...oh well.
Thanks also for the advice
08-14-2006, 04:47 AM
Re: Air Cleaner?
Have fun,, did someone say there is a air purification filter as well?? where is this?. can it be cleaned.
08-14-2006, 03:38 PM
Re: Air Cleaner?
You need to pry and bend. It will not break but German engineered it is not.
08-14-2006, 03:45 PM
Re: Air Cleaner?
X2! I was like WTF, thought it was going to break, then "POP"!
08-14-2006, 08:39 PM
Re: Air Cleaner?
I found that it also helps to remove the three screws that hold the entire assembly down. Then you can twist it out enough to lift the cover off more easily.
08-15-2006, 08:00 PM
Re: Air Cleaner?
Done, thanks for the help, it wasn't as hard as I thought. I appricate all the advice
