Old 08-26-2006, 08:40 AM
Sportsdude's Avatar
Sportsdude Sportsdude is offline
Sportsdude is off the scale
Default Need suggestion on wiring.
What is the best option to route wiring from the outside rear into the cabin of the H2? Another question: what type of drill should I use to make a few small holes to mount rear fog lights to the steel plate right under the rear bumper? I have tried several drill bits and no luck in making a hole after half hour of drilling. Is there a technique? Thank you.
2005 H2 SUV (Yellow)
2003 Vert Supercharged
Old 08-26-2006, 03:45 PM
WHOSNEXT's Avatar
WHOSNEXT WHOSNEXT is offline
Default Re: Need suggestion on wiring.
Behind the right rear tail light I ran wires into the cabin, there is a hole in the bottom to get wires in from the outside and on the side of the tail light cavity there is a hole to get them in the cabin, hope this helps
Old 08-27-2006, 10:33 PM
Sportsdude's Avatar
Thank you. I'll give it a try
