Old 08-29-2006, 12:59 AM
2xtreme's Avatar
2xtreme 2xtreme is offline
2xtreme is off the scale
Exclamation Using oil between changes
Has anyone else here noticed there H3 using oil between oil changes? I am using mobil1 synthetic and going on a 6000 mi schedule. At about 600 mi left before changing it again I checked the level on the dipstick and it was low I had to add 3 qt. This isn't normal, I haven't seen one drop of oil anywhere I park either. The truck has 11400 mi on it.
Old 08-29-2006, 01:11 AM
Default Re: Using oil between changes
I just switched to Mobile 1 (about 200 miles ago). I'll keep an eye on it.
Old 08-29-2006, 03:13 AM
fourfourto's Avatar
I switched to mobile 1 at 12,000 miles,I just changed it at 18,000 checked level 1 week before oil change it was at full. 3 qt's down is alot
Old 08-29-2006, 03:23 AM
I think yopu should get your rig into the dealer! That seems like alot to be low...unless it was misfilled?!?!?!?!
Old 08-29-2006, 05:37 AM
H3slate's Avatar
H3slate H3slate is offline
I have not had that issue. I just switched to Royal Purple. 3 quarts is a lot to lose, it should take 1 qt to go from E to F on the dipstick. Any oil residue around the oil pan drain bolt or oil filter? Does your rig smell like burnt oil after driving for awhile? All worth checking out.
Old 08-29-2006, 05:38 AM
ziemann ziemann is offline
ziemann is on a distinguished road
I am running Mobil 1 EP w/ Mobil 1 oil filters. 7500 miles so far on this OCI and not a drop used. Completely full. Something is really wrong if you are burning that much oil...
Old 08-29-2006, 10:51 AM
Take it to the dealer and have them do an oil use check. They will fill up the engine, seal it, and have you check it every few hundred miles. Then after a set period they will determine the oil usage.
Every engine uses oil, it has to, if not the rings would be sliding on dry cylinder walls and that is not good. However, oil usage is low, and 3 qts in 5500 miles is excessive.
Old 08-29-2006, 05:27 PM
Exclamation Re: Using oil between changes
3 Quarts Monitor carefully something wrong!
Old 08-29-2006, 05:48 PM
Just switched to mobile 1. thinking maybe it wasn't filled to beguin with?
Old 08-30-2006, 01:03 AM
2xtreme's Avatar
I checked it a month or so ago and it was full. Taking it to the dealer tomorrow, and have it checked out.
Old 08-30-2006, 01:28 AM
No measurable usage (via dipstick) between changes using regular oil.
S.
Old 08-31-2006, 01:00 AM
fourfourto's Avatar
Just wondering Wouldnt(or shouldnt) the oil light go on at 2 or 3 quarts low.
Old 08-31-2006, 11:26 AM
2xtreme's Avatar
That's what brought it to my attention. When I took a few sharp turns I heard a ding and the light illuminated for a second then went out.
Old 08-31-2006, 11:19 PM
sltbluh3's Avatar
sltbluh3 sltbluh3 is offline
sltbluh3 is off the scale
I swicthed to Castrol synthetic @10,500 sitting at 18,500 now, dipstick still shows full and the last email from onstar showed 63% oil life left. Something is not right with the engine!!!!
Slate Blue, Luxury Package, Chrome Package, Chrome Rims,XM,Chrome step tubes,trailer package,Air Raid throttle body,SMA cold air induction,GHL Exhaust
Old 09-01-2006, 01:17 AM
2xtreme's Avatar
Yeah I called the dealer today, they want me to put some miles on it this weekend and monitor the oil. Tuesday they want me to bring it in to look at it.
Old 09-01-2006, 01:51 AM
In about 1998 during the early LS1 days, GM had a piston ring fluttering issue that caused much higher than normal oil consumption. Many people went to the dealer after loosing a quart or more in 3000 miles and they were told that this amount of oil loss was not excessive. Be persistent with the dealer - hold your ground.
Old 09-02-2006, 03:04 PM
2xtreme's Avatar
Would that have something to do with the clattering sound I get when backing out of the accelerator?
Old 09-02-2006, 05:33 PM
I don't know. LS1's had some piston slap issues and the I5 has a special table for piston slap when cold. Do you hear the noise when cold?
Do you notice and blueish smoke coming from the exhaust? I'm wondering if you have a valve guide issue that is making some noise and letting oil get burnt in the combusion.
F5 is a good one to ask about this.
Old 09-03-2006, 03:10 PM
2xtreme's Avatar
It generally does it when I am doing 30 mph or higher, and is usually warm. As for blueish smoke I haven't noticed any smoke.
Old 09-03-2006, 11:57 PM
Have the dealer run an oil usage test on the vehicle. They top off the oil, seal the stick and the drain plug and have you come back at different dates to have it checked.
If an engine has piston slap, it goes away when the engine warms and parts start to expand.
