  #41
Old 08-31-2006, 01:58 PM
md_sailor's Avatar
md_sailor is off the scale
Default Re: Gas Tank Holder On Factory Swing Away
Originally Posted by Mr. I - Man
Here are the pics
Thanks for the pics! Great Set up. That site makes me miss my Defender 90. I was hoping you could post a pic of the area where its mounted to your tire carrier with the carrier open. Just curious about how you attached it.
Old 09-01-2006, 05:15 PM
Mr. I - Man's Avatar
I ll try to put more pics up this weekend. the issue I have had with this setup is the Scepter Jerry can likes to expand alot with altitude change and temp change (so the thing cants to the side about ten degrees) so I should move the mount over to the left more and up a bit so I still have access to the release paddle. One other thing is make sure you leave the spare on when marking the mounting holes because every tire is diffrent and you want thing to fit right. I also added a 90 degree bracket on the bottom, because when empty there was not enough weight on the carrier to keep it from bouncing upward.
Old 09-04-2006, 04:53 AM
Alan06SUT's Avatar
Jst ordered the rover part....Thanks Iman.
