Old 09-01-2006, 04:11 PM
OneBadH2 OneBadH2 is offline
OneBadH2 is on a distinguished road
Default Need help quick
I am new to Hummers and I just got one 3 months for a graduation present from my parents. Yesterday I decided to change my oil because I needed to save some money. I'm sure you all know how much gas these things suck down. Anyway, I pulled the plug and drained out all the oil. I have one of those oil filters with the magnet on it so I didn't need to change the filter. Anyway, I went to fill the oil back up and it only took a qrt before it said full. I also found it strange that the oil I put in was a brownish color and the oil I took out was red. Anyway, I headed to a friends house last night and I start to get this grinding noise. I have no idea what it could have been. I was doing about 75 at the time so I immediately pulled over. I checked it over and saw no problems. I start down a side road and get more grinding. I do a few stop and go's to see if for some reason it was the brakes. I drove it to the Hummer dealership today for them to look at it. I hope they find the problem and get it fixed real quick. Any ideas what could have gone wrong?
Old 09-01-2006, 04:17 PM
Default Re: Need help quick
If you were real, this would be a funny story! Drain the Front diff, then top off the oil. Classic!
Old 09-01-2006, 04:20 PM
Jeffery Jeffery is offline
Jeffery is on a distinguished road
Did you get mud in your wheel bearings?
Old 09-01-2006, 04:42 PM
SnakeH2's Avatar
SnakeH2 SnakeH2 is offline
Old 09-01-2006, 05:00 PM
That is all.
Old 09-01-2006, 05:05 PM
tomp's Avatar
tomp tomp is offline
Sounds like you drained the ATF fluid out of the Transfer case and then topped of the engine oil. Classic F/U!
Grinding is caused by burning up your transfer case with no fluid in it!
Old 09-01-2006, 05:54 PM
devilsfan's Avatar
Default Re: Need help quick - I'm trying to be funny
Bad monkey! No graduation for you!
Stacy
Old 09-01-2006, 06:00 PM
I think I know where the diff is. I did not drain the Diff. The dealer told me that they use synthetic in these things and the oil might look a little funny once I drained it. If they told me to do it and it is screwed up then I will just have to have my parents get involved.
Old 09-01-2006, 06:16 PM
No you did. Leave your mammy and pappy out of this, dealerships don't like tattletales!
Old 09-01-2006, 06:32 PM
Big Z Big Z is offline
You Might Try Putting 2 cup of Sugar in the fuel tank!........It'll make er run A Little Sweeter! And, Also Clean the Injectors!
Old 09-01-2006, 07:01 PM
Is this real?
S.
Old 09-01-2006, 07:02 PM
Before you go to the dealer, make sure it's synthetic. Taste a spoonful or two. If it's not synthetic it will feel rather gritty on your teeth and will taste a little oily.
Old 09-01-2006, 07:07 PM
Old 09-01-2006, 08:05 PM
They called me back and said that it was the transmission. They said that some how the fluid leaked out. I told them that I had just changed the oil and never touched the transmission. I had my dad talk to them and he is threatening a lawsuit. That should show them.
Old 09-01-2006, 08:08 PM
Redneck Jeepers bring teh funnay.
Old 09-01-2006, 08:31 PM
lonePalm's Avatar
lonePalm lonePalm is offline
lonePalm is on a distinguished road
I just graduated from Retard school, do I get a hummer? This is my family photo....
Old 09-01-2006, 08:34 PM
That's pretty funnay!!
Old 09-01-2006, 08:35 PM
twenty2's Avatar
twenty2 twenty2 is offline
now... did you learn anything about this mishap??? Have someone do it for you if you don't know what the hell you're emptying and filling.
Also, since you're new to this forum, make sure you don't forget to fill the horn fluid!!! Every month, that needs to be checked. Especially if you use the horn alot.
And, tell you mom and dad about it too.
