Old 09-10-2006, 09:10 PM
Default Re: Which Bumper Winch is the Best
H2 Bully, don't forget to check into Mile Marker winches. I have a Warn simply because I got it from someone that didn't need it anymore.
And, why hasn't anyone mentioned the hydraulic winch? Aren't they supposed to run if the car won't start, or has stalled? (I realize this wouldn't be a usual issue with a brand new H2, but I thought I'd bring it up.)
Old 09-10-2006, 09:31 PM
Originally Posted by PhilD
H2R, Hyrdaulic winches will only run if the engine is running, electric winches will run for as long as there is battery power, which may not be very long with a winch drawing on it, but it is better than nothing.
Thank you, I was just looking at the Mile Marker website. Looks like the hydraulic would run under water. And the 9000 lb hydraulic is 93 lbs shipped. The 12000 lb winch is a whole 98 lbs. That's heavy, but if it's in the bumper she wouldn't ever have to lift it.
Old 09-10-2006, 10:10 PM
Alan06SUT's Avatar
Does T-Max make a multi mount winch that will fit our trucks? I saw Lotus4's t-max at tellico and it was sweet. All I've herad is good things about these.
Old 09-11-2006, 02:15 AM
H2 BULLY's Avatar
H2 BULLY H2 BULLY is offline
This Thread Rocks
T & A RULES ESCALATOR
Kiss my AXLE
Old 09-11-2006, 05:29 AM
Yes, but they are ugly. She cannot have an ugly winch. K?
Old 09-11-2006, 02:26 PM
lotus4s's Avatar
lotus4s lotus4s is offline
HEY HEY HEY, don't you be talkin' bout my winch now, I'll slap yo mama...
Old 09-11-2006, 05:56 PM
Originally Posted by H2 BULLY
This Thread Rocks
X2
Old 09-11-2006, 11:18 PM
X2
How come I can't view your picture CO?
Old 09-11-2006, 11:31 PM
Dunno. Think it's your 9600 baud modem? I can see it.
How bout if I link it, here. Rock ON!
Old 09-12-2006, 03:58 AM
That's one worth filing!
BTW, I'm at 50K on a good day.
Old 09-12-2006, 04:07 AM
Alan06SUT's Avatar
Cant you see I'm just trying to copy your truck Lotus!!! Coopers and T-max???
Old 09-12-2006, 05:26 AM
Arizona Hummerboy's Avatar
I am runing the Warn 9.5TI Multi Mount, I like the fact that I can winch from the front or back. And when not in use I store the Winch in the back of the Hummer were the Third Seat was.
Name:  Raw Deal # 00.jpg
Old 09-12-2006, 08:34 PM
lotus4s's Avatar
Yeah and that H2 Rocks bish was calling our winch ugly.
Old 09-12-2006, 08:55 PM
[quote=PhilD]
Rockstomper.com has the Amsteel stuff at a pretty reasonable price.[/quote[About the going rate by the time you add a hook, although I don't particularly like the ones they offer.
5/16" is fine and about the same strength as 3/8" steel cable.
Not sure i'd say it is overkill. You shouldn't shock load a winch line, but it will happen from time to time and the extra strength of a 3/8" line may be important in those instances.
Not sure about that, but I know people use 3/8" x 100' with the 9.5XP, I'm pretty certain that's what Paragon's got on his also.
I'd personally go for 3/8" line, but it is definitely not necessary and 5/16" will do the job.
Yeppers, I have 100' of 3/8" spooled up and also have a 50' extension.
I had no considerations of doing anything less than 3/8" and I run the Masterpull line which is rated at 23.5K lbs. You would have to get the 7/16" in Amsteel to get the same kind of weight rating.
Also, Masterpull and Trail Duty stood behind their line (not saying no other mftrs do) when I had a failure during Hurricane Katrina.
Old 09-12-2006, 11:44 PM
What was the failure? Did you try to pull something that was 23.6K lbs?
Old 09-13-2006, 04:02 AM
Alan06SUT's Avatar
Old 09-13-2006, 09:00 PM
Did I hit a nerve? I'm sure it's a fine winch.
Old 09-13-2006, 09:34 PM
lotus4s's Avatar
that's more like it..
