  #41
Old 09-13-2006, 06:40 PM
Default Re: Torsion Bar Information
Ok let me ask more specifically.
How are the BDS's working? Have you installed them?
I looked up the part numbers and it shows they are for the Chevy/GMC 4WD K1500 (nonHD) 99-06 6" lift.
Did you have to modify the mounts at all?
Why BDS ? What are the actual length of the shocks?
Thanks, Bebe
Old 09-14-2006, 12:06 AM
cestwick's Avatar
cestwick cestwick is offline
cestwick is off the scale
How are the BDS's working? No prob's noted. Have you installed them? Yes. I replaced rear shocks.
I looked up the part numbers and it shows they are for the Chevy/GMC 4WD K1500 (nonHD) 99-06 6" lift. That's right.
Did you have to modify the mounts at all? no.
Why BDS ? What are the actual length of the shocks? Extended length is 2 inches longer then factory. Giving you 4 more inches of travel at the wheel. You will have to remove rear sway bar or get a different sway bar link. they will not extend the extra inches and will pop out of there socket. I just removed whole bar. Have not had any probs. Gm's never had sway bars on solid axles before I haven't noticed any extra body roll....
Thanks, Bebe
'06 H3 Shadow Green, Adventure, 6 disk Monsoon, SMA brush guard w/PIAA lights, Rocky Road extreme rocker protection, roof lights(off road), lower grill lights(off road), Helo Maxx8 Black Wheels, 35" Cooper STT, Garmin I-Que M4 to get home.
Old 09-14-2006, 12:15 AM
OK,thank you.
Did you keep the front shocks stock? You had noted that you turned your T-Bars, 7-8 turns, did you not get longer shocks for the front???
Old 09-14-2006, 12:22 PM
Ipedog's Avatar
Ipedog Ipedog is offline
OK,thank you.
x2 - This would be an interesting thing to know. Would the H3 benefit from longer shocks up front OR would the longer shocks become a problem at the upper limit of the front suspensions travel?
Would it be better to instead have a bracket fabricated comperable to the Truxxx shock extension bracket as the range of motion remains the same?
Shock extension brackets shown on right.
Rob (Ipedog - Say "Ip-E-Dog")
Black Sheep HUMMER Squadron
Old 09-14-2006, 01:27 PM
cestwick's Avatar
OK,thank you.
Yes I kept the front shocks factory. You would not benefit much from longer shocks in front because you are limited in the travel by the whole geometry of the front suspension. I do believe the brackets from Truxx would help the stiff front end if you crank the torsion bars up to the point it tops out the shock. The top shaft on the shock is long enough I just put a spacer between the shock and the lower bushing washer, efectively alowing the shock to sit lower in the mount and let it extend a little further.
Old 03-30-2007, 06:00 PM
BTT, anybody seen cestwick???
I have a couple of questions.....
Old 03-30-2007, 07:58 PM
cestwick's Avatar
Last i know he was working at a T*y**a Dealership.
What can i do for ya?
Chris
Old 03-30-2007, 08:02 PM
I had my shackles built, just wanted to know if there is any feedback from your set up? It's been a while since you installed.
I have a 2" extended shackle.
Old 03-30-2007, 08:14 PM
Also, I found a Rancho 99227, from a 1 ton suburban 4" lift REAR, is 1" longer, all the same mounting, closed barpin, etc., and I think it's the same as the BDS you mentioned earlier in this thread.
I found some Hellwig adjustable end links, and some helper springs.
The Avalanche front shock Rancho 99268, is the same size as the H3 but with 6"'s of travel, vs 2.34 that Rancho has for the H3, and 4"'s that the stock shock has.
Think this will work?
Old 03-30-2007, 08:19 PM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
Also, I found a Rancho 99227, from a 1 ton suburban 4" lift REAR, is 1' longer, all the same mounting, closed barpin, etc., and I think it's the same as the BDS you mentioned earlier in this thread.
Only if you put a 12" lift on your Hummer
Old 03-30-2007, 08:28 PM
1"
Old 03-30-2007, 09:21 PM
Hey look I just passed 5000 posts.
Old 03-30-2007, 10:02 PM
Talking Re: Torsion Bar Information
Aren't most people over 5000 posts either banned, jailed, deported, or missing for good reason?....
Old 03-30-2007, 11:36 PM
cestwick's Avatar
I can't say that i have had any problems in the back or noticed anything good or bad, other then the fact that with extended travel in the rear from long shocks you will have to change sway bar links or remove the sway bar all togather(which is what i did). The stock links will not twist enough and will pop out of the joint when articulated.
Old 03-30-2007, 11:40 PM
Like I said, Hellwig products makes the end links that are adjustable. I called and they said it will work for an H3...
Are they important to have? or have you been OK without your Sway Bar?
Old 03-30-2007, 11:41 PM
cestwick's Avatar
I don't see why that wouldnt work. The front shock will have more travel then you can use with the front bump stops, but if you raise the bars a little more then you have now to match the rear you will need the extra travel to keep front for topping out the shock and causeing the rough ride.
Old 03-30-2007, 11:42 PM
cestwick's Avatar
I havent noticed one bit that the rear sway bar isnt there....If you look at 90% of the trucks on the road they dont have rear sway bars
Old 03-30-2007, 11:58 PM
I can't wait till I have flex like this
Old 03-31-2007, 12:26 AM
Doesn't look like much more than stock.
Old 03-31-2007, 12:35 AM
Yeah it does, we both have 33's in those pics, he's got 35's on and it still looks like more flex.
AND QUIT PEEING IN MY CHEERIOS DAMMIT!!!!
But it is kinda funny to see our trucks from sooooooo long ago.
