Old 09-14-2006, 02:51 PM
cmesurf cmesurf is offline
cmesurf is on a distinguished road
Default 2006-H2 Rearend or Tranny Briefly Slips/Jerks When Accelerating from Dead Stop
Any Ideas? I am experiencing a brief slipping/jerking when accelerating from dead stop? Does not occur when accelerating 'Gently' from dead stop. Seems to have started after I fiddle Farted with the TC2 and Trailer Towing buttons. Read manual...buttons corrected to normal. Feels like rear end but could be in tranny area..not sure. Driving me nuts... Thanks.
Old 09-14-2006, 03:12 PM
Big Z Big Z is offline
Default Re: 2006-H2 Rearend or Tranny Briefly Slips When Accelerating from Dead Stop
Could be just a program update needed. Pushing those buttons shouldn't matter!...I use the Tow/Haul all the time.
Old 09-14-2006, 03:14 PM
Thanks, Z...Should I just take it to the dealership or is there an easier fix? Thanks...Cat
Old 09-14-2006, 03:35 PM
Dealership!
Old 09-14-2006, 09:28 PM
tomp's Avatar
tomp tomp is offline
Default Re: 2006-H2 Rearend or Tranny Briefly Slips/Jerks When Accelerating from Dead Stop
Probably typical GM drive shaft yoke sliding on tranny shaft. Do a search on clunk or clunking and you will see it's common. It's not just the H2 either.
There was a service note that came out for this for some year/models.
Old 09-14-2006, 11:28 PM
NSANE NSANE is offline
NSANE is off the scale
I tow with my 06 all the time. I had a jecking in mine but it was the rear lower control arm bushings which the dealer repalce and no more bad feelings in it.
2006 H2, Black with bling!!
Old 09-15-2006, 01:50 PM
Default Problem Solved!! You Aint Gonna Believe it.......
Well, I took my H2 to the dealership yesterday and had them check my slip/jerk/clunk...Turns out that the day before I had the vehicle washed/vaccumed etc...the 'kids' that wiped down the inside failed to Close the Spare Tire Carrier Securely, but, they did insert the lock pin, so, whenever I would stop the carrier would move forward a bit and, then, when I accelerated the bar would slip backward into the steel cable holding the pin making the Clunk sound. Do I feel stupid or what? Thanks for all your replies...
Old 09-15-2006, 02:12 PM
Default Re: Problem Solved!! You Aint Gonna Believe it.......
[quote=cmesurf]Well, I took my H2 to the dealership yesterday and had them check my slip/jerk/clunk...Turns out that the day before I had the vehicle washed/vaccumed etc...the 'kids' that wiped down the inside failed to Close the Spare Tire Carrier Securely, but, they did insert the lock pin, so, whenever I would stop the carrier would move forward a bit and, then, when I accelerated the bar would slip backward into the steel cable holding the pin making the Clunk sound. Do I feel stupid or what? Thanks for all your replies...[/quote
ROFL......Glad It wasn't serious!
Old 09-15-2006, 02:56 PM
ree's Avatar
ree ree is offline
It happens. Sometimes you just need an extra set of eyes/brains on a problem and find it's quite simple.
'03 pewter base H2
Old 09-15-2006, 03:26 PM
Motohead's Avatar
Motohead Motohead is offline
I had my tranny slip once.
So I bought him non-skid high keels.
Tranny... get it... high heels... haha... ummmm ...errr...
Old 09-15-2006, 08:43 PM
Glad it was nothing much, I have kids too and been there done that.
