Old 09-15-2006, 07:02 PM
Default stuck bolt! argh!
The top front bolt of my assist steps mount won't budge! Any suggestions? I've used an 18" ratchet extension, normal ratchet, adjustable wrench and so on and it's not budging, been trying for like an hour and all it's doing is stripping it. and I'm the one that tightend it last!
Old 09-15-2006, 07:03 PM
Default Re: stuck bolt! argh!
WD-40???
Old 09-15-2006, 07:23 PM
fourfourto's Avatar
Originally Posted by HummBebe
WD-40???
X2
Heat it up
Impact wrench.
Cut it off and replace bolt.
Old 09-15-2006, 07:44 PM
Desert Dan's Avatar
WD-40 and wait a few minutes.
Are you sure you are turning the correct way?
Don't laugh we have all that before
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 09-15-2006, 08:05 PM
spark spark is offline
spark is an unknown quantity at this point
I've had better luck with liquid wrench,
Old 09-15-2006, 10:22 PM
deserth3's Avatar
deserth3 deserth3 is offline
Heat the bolt. Carefully
Old 09-15-2006, 10:25 PM
Use a box end instead of the socket, you can hammer on it a little.
Old 09-15-2006, 10:57 PM
Liquid Wrench then hot & cold.
Old 09-15-2006, 11:40 PM
Alan06SUT's Avatar
Bigger wrench or put a pipe on a ratchet to make it longer, thus more leverage.
Old 09-16-2006, 01:15 AM
thanks, took like 3 hours but I finally got both of them! Had to use all the suggestions.
Old 09-16-2006, 01:35 AM
Now, anybody have the p/n for those bolts?
Old 09-16-2006, 01:56 AM
fourfourto's Avatar
Just match them up at the hardware store.
Buy the strongest ones they have in stainless,and replace them all
Put a little anti sieze on threads.(used for lug nuts,spark plugs ect)
Old 09-16-2006, 01:02 PM
I agree, anti-seize is good for these bolts, but beware, NEVER use them on lug nuts. Lug nuts are designed to torque to a specific spec DRY. Adding any type of anti-seize to a bolt/stud will cause incorrect torque.
Old 09-16-2006, 05:46 PM
crop000's Avatar
crop000 crop000 is offline
crop000 is on a distinguished road
What is the torque spec for the lugs??
Old 09-16-2006, 06:59 PM
103 lb ft (140 N?m)
And I'll even through in the GM fastener notice:
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Old 09-16-2006, 07:58 PM
deserth3's Avatar
I'd stay away from Stainless Steel bolts. They are known for galling. Stainless bolts are good if you plan on not removing them and don't want any rust. But for an aplication that needs to be removed numerous times Stainless doesn't work so well.
Here's a little more information about it.
http://en.wikipedia.org/wiki/Stainless_steel
Old 09-16-2006, 08:53 PM
Khoolhandz Khoolhandz is offline
Khoolhandz is on a distinguished road
Galling only occurs when both parts are stainless steel and completely dry. If the other part is steel and the bolt is stainless, galling is not an issue.
Also, if galling is a concern, a little bit of anti-sieze (note: little bit) will prevent galling if both parts are stainless.
I work with stainless steel bolts as a profession.
Besides, stainless steel (Depending on the grade, but most common is 18-8 unless you go to specialty stores) is not the strongest. If you want strong, I'd go with carbon steel bolts.
Old 09-17-2006, 04:09 AM
jp's-h3 jp's-h3 is offline
WD-40 ROCKS!
