Old 02-25-2006, 09:38 PM
Alan06SUT's Avatar
The thread in the h3 forum got me interested in how the ghey wagon would compare to h2 stock vs stock.
Here is the specs I could find...
As typical for Mercedes vehicles, the G-Wagon is optimized to the use its designed for: It is safe, reliable, offers lots of room for passengers and cargo and goes as far as you can expect a car to go. It climbs up and down up to 80% grades, and is stable on lateral slopes up to 54%. Fording depth is 48cm (19in) (Manufacturer’s Specifications). Certainly, the G is more designed for off-road performance than most other SUVs, especially when it comes to durability, yet it is the most practical car on the road to get your groceries, to bring the kids to their favorite sports events, or just to get to work safely whatever the weather might be. Besides that, the G-Wagon offers a trailer tow capacity up to 3,500 kg (7700 lb) GTWR, depending on the engine choice.
80% grade??? BS. I'd like to see that.
54% side slope how many degrees is that like 46 or something, ok I belive that.
Water fording 19 in versus 20in in h2 pretty close.
What are the approach/departure angles? Cant find the info.
Also towing is fairly comparable.
We might have a pretty good competitor, but price and gheyness factor tip heavily toard h2. Also, the tires are small and street. Fukk that. You would have to add at least mud tires to climb even a 60% grade IMO.
Stock tires vs stock tires Hummer wouldn't even have to leave the pavement to out do the G-fagon.
G wagon owners, do your best to prove me wrong and then I'd like to hit the trails w/ one.
Also all name calling is said in jest (SIC?) and should be taken that way.
Old 02-25-2006, 10:04 PM
Alan06SUT's Avatar
Here is the most extrerme gwagon pic I could find.
Old 02-25-2006, 10:24 PM
Alan06SUT's Avatar
Not scared yet....
Old 02-25-2006, 10:31 PM
Alan06SUT's Avatar
The g-wagon...Self proclaimed "the best 4x4 ever" but no good pics of them doing tough obstacles that I can find.
Here two stuck ones
Old 02-25-2006, 10:32 PM
Ok, I didn't read all of that, but remember the number one word "MARKETING."
The G doesn't have a roof rack which accounts for higher stated slopes. Specs, such as slopes, are reported at Maximum Gross Vehicle Weight Ratings. The H2 can carry, I don't remember what the exact number is but, something like 500lbs on the roof which greatly increases the COG.
54% is probably a little less than 30 degrees or so, which the H2 can do without whimper.
So, you are really not comparing apples to apples using the manufacturer supplied data.
Old 02-25-2006, 10:35 PM
Alan06SUT's Avatar
Here is "extreme conditions" nice pizza cutter tires by the way... Oh and that looks like about an 80% grade so I stand corrected---NOT!
Old 02-26-2006, 12:29 AM
VTSTOMPER is off the scale
Yeah, but it corners like it is on rails!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 02-26-2006, 12:32 AM
da bling club...
http://www.hartwheels.co.jp/download...nocalendar.jpg
Old 02-26-2006, 12:56 AM
Alan06SUT's Avatar
LMAO!! Again Nice Pizza Cutters!!!
Old 02-26-2006, 02:39 AM
Kevin B Kevin B is offline
Kevin B is off the scale
I don't know all that much about them, but anything that comes from the factory with SFA and lockers can't be all bad. It seems like they have a good balance between width and wheel base also.
Old 02-26-2006, 02:45 AM
It is what the British Army is using in Iraq I guess now too! That pic has more flex than a stock H2 I bet!
Old 02-26-2006, 06:46 AM
Alan06SUT's Avatar
Yeah but its not stock!!!
Old 02-26-2006, 11:46 AM
Ernie Italy is off the scale
Here (italy) the Class-G short version is one of the most used (with Def 90) off road car... The big problem for large truck is obiouvsly the mountain...forest...tree and all around.
Yes...I confirm that a stock H2 is more capable than a stock G or Def.... But with some money G and DEF can be modified very aggressive... More money we needs to change H2 to make competitive with G and DEF
Old 02-26-2006, 02:51 PM
dochummer's Avatar
'03 H2
Old 02-26-2006, 02:53 PM
dochummer's Avatar
'03 H2
Old 02-26-2006, 02:55 PM
dochummer's Avatar
'03 H2
Old 02-26-2006, 02:59 PM
G wagon - on crack.
Old 02-26-2006, 03:08 PM
Alan06SUT's Avatar
I'm impressed to see it on crack as well!
Old 02-26-2006, 03:10 PM
Alan06SUT's Avatar
Looks like it is resting on the rear overhang, but making it is making it.
Old 02-26-2006, 03:49 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Originally posted by dochummer:
