09-22-2006, 02:14 AM
Re: I get my H3 in less than 2 weeks! Some questions--
Congrats, great color choice.
Originally Posted by sc2178
Ahhh, I bet it doesn't have it then
If it doesn't have it and you want to get XM, PM me, I have a Terk tuner that will plug right in and you are good to go.
09-22-2006, 03:08 AM
I already have a standalone tuner that I could use. I just figured if it had it built in it would be simple to just switch service to it. Thanks though, I'll keep you in mind
09-22-2006, 01:25 PM
This is a tuner that hooks directly into the factory head unit and is controlled by the head unit as if it was the factory tuner. Not sure if that is what you have or if you have one of the external tuners. Either way, if your interested, just let me know.
09-22-2006, 03:04 PM
I just had one put in as described above, it plugs into the factory radio and then is controlled as if it was there the whole time. Only difference is, is that it has its own antenna. We mounted it above the drivers head next to the track, you can only see it if you know it is there. cost about 300.
09-22-2006, 04:00 PM
Pretty much what I did. I have the XM and GPS antennas mounted right behind my marker lights and next to the roof rails on either side. You can even see them unless you are above the truck.
cost about 300.
 man that's EXPENSIVE!! What kind is it?
09-22-2006, 05:39 PM
Originally Posted by Lex_Ordo
I didn't want XM, and ordered the truck w/out it. The Antenna is still there though because it incorporates the OnStar System.
Same here.
But I believe the XM and Onstar antennas are separate, they're just both in the same housing on the roof.
09-22-2006, 06:50 PM
oR YOU CAN DO A SIRIUS, WHICH IS MUCH BETTER
09-23-2006, 02:34 AM
Fo sho.
06 Adv. nuff said
09-23-2006, 03:17 PM
I tried Sirius too, I prefer XM for the music. Plus I enjoy Opie & Anthony and I don't like Stern
09-23-2006, 03:31 PM
Why are you waiting til the 30th? The "good" incentives end tuesday the 26th!!!! Im curious what you paid if you dont mind me askin?
09-24-2006, 03:21 PM
I already did the paperwork via FedEx. I don't plan on making the trip back to pick it up till the 30th
