Old 09-24-2006, 06:51 AM
marqiux marqiux is offline
marqiux is on a distinguished road
Default HELP WITH THEFT DETERREMENT!! PLEASE!!
Hello everybody,
Alright, I'm having this problem and don't know how to fix it. I think it has something to do with the anti theft deterrement....
here it goes.
Whever I turn off the engine, lock the truck with the remote. Then when I want to leave I try to turn on the truck however it doesn't start - it sounds like it's gonna start but it doesn't......I then turn off the truck, lock/unlock the truck many times with the key.....I honestly do so many things....until I finally get to turn on the truck but don't know what I did it the first place to fix it.....
has anyone had this happened before....Need help please - I had this happened three times already.!!!!!!!
Old 09-24-2006, 06:55 AM
Default Re: HELP WITH THEFT DETERREMENT!! PLEASE!!
Stop stealing trucks! Problem solved.
So the truck is locked with the remote, but you say you unlock the truck many times with the key... why don't you use the remote to unlock?
Old 09-24-2006, 09:15 AM
YEAH !!!
Old 09-24-2006, 10:10 AM
Lex_Ordo
It states in the manual, that if you use the keyless remote to lock the truck, then you must use the keyless remote to unlock the truck.
Using the key in the door will unlock the truck, but also set off the alarm, and I believe it disengages the fuel pump so the motor will crank, but never turn over.
If you use the manual lock on the doors to lock the truck before you close the door, or use the key in the driver's door(since there are no other door key holes) then the truck can be unlocked, using the key without any issue.
The only time the anti-Theft system is activated or de-activated is with the Keyless remote.
HTH
Old 09-24-2006, 04:03 PM
HTH
Isn't that what the Russian and I said ???
RYD
Old 09-24-2006, 05:09 PM
Khoolhandz Khoolhandz is offline
Khoolhandz is on a distinguished road
HTH
Yes, but within seconds before the alarm is set-off, when you put the proper key to the ignition and turn it ON, it should de-activate the alarm and you should be able to drive it.
Something is wrong with his H3, better bring it back to the dealership.
Old 09-24-2006, 07:54 PM
Lex_Ordo
RYD
NO. Dеiтайожни wrote, "So the truck is locked with the remote, but you say you unlock the truck many times with the key... why don't you use the remote to unlock?"
A question was asked, but no explanation was given.
Some people don't read the manual, and whether or not 'marqiux' read the manual is not relevant. It is easier to understand the why when you hear the how to. If nothing else, it is a memory refresher.
Trying to help with what I remember reading.
Old 09-24-2006, 08:03 PM
It was rhetorical.
Old 09-24-2006, 11:45 PM
Originally Posted by marqiux
Hello everybody,
here it goes.
I would say it is the passkey ignition module that needs replacement; however, I'm not there to diagnose. Take it to the dealer and explain what happens.
Old 09-25-2006, 12:12 AM
fourfourto's Avatar
Does everybodys alarm (horn) start with low volume a few cycles then regular volume ?.
Old 09-25-2006, 03:03 AM
Lex_Ordo
It begins low for 10 seconds then starts in loud, and flashes the lights on & off.
Old 09-25-2006, 04:44 PM
however if you lock the truck with the remote several times....does that also trigger something
Old 09-25-2006, 04:54 PM
Not that I know, I usually do it three times.
Old 09-25-2006, 08:04 PM
I just called Hummer and they're saying that if me or someone manually opens/closes the doors without the key fab that would trigger the alarm...the on the truck thinking the truck has been stolen...therefore I shoud then lock the truck with the key fab, open it with the key fab, put the key in the ignition (on) and wait 30 minutes...that would reset the alarm and would allow me to drive the truck... yikes! because what would happen I would return to the truck and try to start it...all it would do it would just crank (try to start) but it'd never start!!! it was so frustrating.......
Old 09-25-2006, 08:21 PM
What are you talking about? It's not a hard concept... you lock with the remote, you unlock with the remote.
Old 09-26-2006, 12:03 AM
Lex_Ordo
Question Re: HELP WITH THEFT DETERREMENT!! PLEASE!!
Marqiux, I'm sorry but I am having a real hard time understanding your english?
Dеiтайожни, is right. What part aren't you getting?
Old 09-27-2006, 01:08 AM
ONLY USE THE REMOTE
DO NOT
I REPEAT
DO NOT
insert the key ino the little hole in the drivers door...
PROBLEM SOLVED
RYD
Old 09-27-2006, 01:10 AM
jus....klick klick klick klick it
Old 09-28-2006, 11:39 PM
Dani Dani is offline
Dani is off the scale
ONLY USE THE REMOTE
DO NOT
I REPEAT
DO NOT
PROBLEM SOLVED
RYD
My 12 yr old daughter tried to unlock my H3 w/the key and the alarm went off. Needless to say- she's scared to death of it now.
If the broom fits, fly it!
Old 09-30-2006, 12:09 AM
I didn't know they issue Drivers Permits to 12 year olds
