Old 05-19-2004, 01:51 PM
Hog Hunter Hog Hunter is offline
Hog Hunter is off the scale
I bought a used factory brushguard for my 2004 H2. Two of the six bolts I was to receive were lost in shipping and I replaced the missing items with the same size bolts as the four I initially received. After attempting the install last night I have come to the conclusion that these are the wrong size bolts for the upper mounting brackets. I think these should be narrower to enable them to fit throught the upper mounting bracket. Assuming I am correct and this works out,(also, is the procedure to slip a spacer over the bolt on the upper mounting bracket?) it appears that the grill needs to be cut to fit over the brushguard support. Can someone please confirm?
Pewter 2004 H2, Warn Winch, Husky Mats, No leather or sunroof, Garmin rino 120, stainless DSA FAL carbine w/ aimpoint red dot and my trusty cocker spaniel.
Old 05-19-2004, 07:50 PM
Tucson Beast
I have a factory brushguard - I have also replaced my grille (chrome to black) and I have never had to cut the grille as I removed and re-mounted my brushguard. Check with your Dealer in order to help with bolt size - no cutting is required.
Old 05-19-2004, 08:01 PM
HHummer's Avatar
HHummer HHummer is offline
HHummer is off the scale
The factory brush guard came with a replacement grill that is smaller than the original.
Old 05-19-2004, 09:43 PM
HummMe
The top two grille bolts have spacers. These are also longer thinner bolts. Then the lower valance(black grille),that mounts in front of the lower brushguard mounts, gets trimmed. They all do. On the back of it there are lines for you to trim to fit around the brushguard mounts. You will see it clearly marked.
Old 05-19-2004, 09:59 PM
HummerLV's Avatar
HummerLV HummerLV is offline
HummerLV is off the scale
what hummme said is correct, i just finished doing mine.
Old 05-20-2004, 02:58 PM
Thanks for the input.
