09-28-2006, 11:49 PM
Might need new H2 sooner
09-29-2006, 12:00 AM
Re: Might need new H2 sooner
That blows! Sorry to hear that.
09-29-2006, 12:50 AM
sons a bitches.....thats all i can say....sons a bitches.....
2009 H2 Silver Ice LE
09-29-2006, 04:04 AM
That does suck, in a bad way!
2006 H2, Black with bling!!
09-29-2006, 05:59 AM
OUCH! Time for a Duramax upgrade!
'03 H2
09-29-2006, 03:15 PM
Originally Posted by PhilD
Mine was like that after the dealer did the 15k service. 30k miles later no problems.
It is really to do, and extra care needs to be taken when putting the intake tube back on.
That would explain the blue smoke coming out of you........... ummmmm
nevermind,
really? no problems.
09-29-2006, 04:40 PM
Originally Posted by PARAGON
I don't understand, Un-Filtered Air is organic and nutrient rich just as God had intended. So called Filtered-Air may have been altered in the process and lacks the nutrients your V8 needs. Who knows what harsh petroleum derived chemicals left-over from the filtermaking process, make their way into every breath your engine takes. Go natural. Every filter you buy contributes to the Global Warming of the Holes in the Ground-level Ozone Layer.
Dwight: Second Life is not a game. It is a multi-user, virtual environment. It doesn't have points or scores. It doesn't have winners or losers.
Jim: Oh, it has losers.
09-29-2006, 04:49 PM
I was in your neck of the woods when it started throwing MAF codes.
Can you post your address, so I can have a place to go steal... umm.. er.. borrow parts in case I break some in a couple of weeks. Coming back over to Bham to do more vehicular damage.
09-29-2006, 04:59 PM
 It's shame you can't rely on repair shops or dealers (or even Jiffy Lube for that matter).
I can help you out if you need anything welded.
09-29-2006, 05:06 PM
Yeah that sucks though. You think it is worrisome to have people work on your truck these days, try having them work on your airplane. we have had engines ingest airfilters that were not secured properly or installed inside out. A 550 cubic inch 6 cylinder will suck the filter right down into the cylinder in a flash
09-29-2006, 05:12 PM
about that address
09-29-2006, 07:55 PM
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
09-29-2006, 08:06 PM
09-29-2006, 09:47 PM
Originally Posted by H3HUMMER
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
09-29-2006, 09:58 PM
I can help you out if you need piano or sewing lessons..
FIXED!
09-30-2006, 02:00 PM
It get's worse
Drove to the farm yesterday and was turning around to back in to a spot. It's a little drop and I was wheels cut full to driver. Had a clunk.
Been having a clunk and it felt like the skid plate as before.
This time I felt it strong in the steering. Got to going back and forth between Drive and Reverse and it was clunking bad. Crawled under while someone else shifted back and forth and the DS output shaft is where it is coming from. Was hoping it was CV related but I swear most of the movement seem to occur near the Diff
Really "acts" like the inboard CV is going out but it gives you the illusion that the output shaft on the diff "wobbles" around when you go from D to R and back and forth. But, there is no leaking of fluid there.
Will investigate it further when I get back to the house.
