Old 10-02-2006, 02:38 PM
W1N's Avatar
W1N W1N is offline
W1N is off the scale
Default Service includes, what?
What does the basic service include? Oil change? I'm closing in on my first service now
Old 10-03-2006, 05:34 AM
W1N's Avatar
W1N W1N is offline
Default Re: Service includes, what?
Originally Posted by PhilD
I'll save you the trouble of looking in your owners manual
Oil/Filter Change
Chassis Lube
Rotate/Inspect Tires
Inspect Brakes
Check Engine Coolant
Check Air Filter
Thanks! Reading the manual has been always troublesome anyway
Does the engine oil life go back to 100% automatically when you do the change oil? Or do you have to set is somewhere by programmer?
btw, do you guys do the service yourselves?
Old 10-05-2006, 12:01 PM
W1N's Avatar
W1N W1N is offline
Again, I'll save you from reading the manual Display the oil life and hold the reset button (the one that looks like a the return key on your keyboard) for 5 seconds.
Yes, just because I know everything will be done that way.
Thank again!
Do you know how the computer determins the engine oil life? What would happen if you just reseted it without chaingin oil. Would it be able to recognize old oil and show the oil life acconrdingly? And the same way with new oil, that is can always show right oil life?
thanks!!!
Old 10-06-2006, 07:54 AM
W1N's Avatar
W1N W1N is offline
No, it does not do a chemical analysis of the oil or anything that sophisticated. It is simply based on mileage and driving conditions. Ot does not monitor oil level either, so it is worth checking from time to time.
So it is just like an independent indicator for the driver???
Old 10-06-2006, 04:54 PM
Lean Machine's Avatar
Lean Machine Lean Machine is offline
Lean Machine is off the scale
W1N,
How are the 22'' rim and tire setup working for you? Any issues with rubbing yet?
\'05 H2 Lux Pewter SUV, Nav, Air, Sunroof, 22x10 E Forged EF16 with BFG Limited Edition Mud-Terrain T/A 335/55R22 and varies Chrome Parts
\'08 H2 Lux White SUT with Sedona interior - SOLD
\'08 H2 Lux White SUT with Sedona interior and 6'' Fabtech Lift
Old 10-07-2006, 03:05 PM
W1N's Avatar
W1N W1N is offline
Originally Posted by Lean Machine
W1N,
No issues, little rubbing, but nothing that really bothers me at all. I definately would recommend those rubbers to anybody, they are really good looking. Now that winter is on the way, I'm little sceptical about the perfomance on ice and snow. I'll let you know how it turns out though
I plan to put out more pictures as I get it done, but too much work lately to try to that...
