  #81
Old 03-23-2006, 02:32 AM
you said MOUNT
Old 03-23-2006, 02:35 AM
westhillsat's Avatar
Originally posted by NEOCON1:
SSSWWWEEEETTT BBRRROOOOO they look awsome west congrats now add them puppys to your sig
Thanks Neo and added to sig
Old 03-23-2006, 02:41 AM
Nav4-NEOCON1's Avatar
Nav4-NEOCON1 Nav4-NEOCON1 is offline
Nav4-NEOCON1 is off the scale
hi west nice tires , looking forward to meeting you and the family in a few weeks .
Old 03-23-2006, 02:46 AM
Hi
Thanks, its all Neo's fault for getting the bigger ones first
We look forward to meeting you too!!
Moab is getting sooo close now
Old 03-23-2006, 02:59 AM
kennyosemite kennyosemite is offline
kennyosemite is off the scale
Thanks to Neo for the great insight on the Toyos. After reading yesterday's thread, I called the dealer I ordered my truck from and told him to switch the tires out. After turning in the Bridgestone 33's that will arrive with the Adventure package, the total of 5 Toyo tires, including mounting, balancing and torsion bar adjustment, will run me $1075 (i.e. $215 each). Schweeeet. I can't WAIT for this beast . . . 4-5 more weeks. THE SUSPENSE IS KILLING ME
Knowledge is Power.
Old 03-23-2006, 03:06 AM
i do love those sidewalls the wait is the hardest part
Old 03-23-2006, 03:13 AM
Toyo should thank this forum
Old 03-23-2006, 03:50 AM
they could give a set to Lootie
Old 03-24-2006, 01:30 AM
thanks . Christmas again just got home and my lev-o-gauge and hand held C.B. arrived today
Old 03-24-2006, 01:55 AM
Good deal
My gauge is supposed to arrive Monday.
Old 03-24-2006, 01:56 AM
Now you just have to figure out where to mount them.
Old 03-24-2006, 03:14 AM
i gotta take this stuff to the shop with me tomorrow and play with it hope i can find somewhere to mount this stuff
Old 03-24-2006, 03:32 AM
Wile E. Coyote Wile E. Coyote is offline
Wile E. Coyote is off the scale
Neocon1,
For the lev-o-gage, a suggestion might be right on the wind shield just below the headliner. It's pretty flat and that way it's right in front of you and not quite visible from the outside since there is a slight tint on it.
Wile E. Coyote
Old 03-25-2006, 07:51 PM
got some real world testing today
Old 03-25-2006, 07:54 PM
everything was fine a little contact on front sway-bar at lock with wheels stuffed . truck was great no problems after 700 miles on the toyos aired down to 25 psi today also and didant pop a bead
Old 03-25-2006, 09:42 PM
Sean K. Sean K. is offline
Sean K. is off the scale
You're not anywhere near popping a bead at 25 psi. I'd say from my own experience that you should be able to go down to 12 psi without losing a bead.
As for the Level-O-Gauges....NEVER, and I mean NEVER let them determine whether or not you are going to roll.
Something as simple as one passenger in a different seat will compromise the accuracy of such gimmicky devices. They're merely a golly-gee-wiz accessory and will tell you nothing about how close you really are to rolling.
Just a warning.
Sean
Old 03-25-2006, 10:01 PM
well it is a bit of a concern to me with the 315's on a 7.5" wheel .
i will test these the same way i did the stock 285's working my way down 5 psi at a time . i measure for sway-bar rub and dont want it to get to bad as i air down more and more .
next tests will be 20 psi and then steping down to 15 psi and checking rubbing issues as i go .
i ran the stock 33's in pismo at 15 psi and could go wherever i wanted . i also like knowing how the tires perform at different pressure settings . any info you have on 35's on a narrow ass rim is welcome
Old 03-26-2006, 02:03 AM
FWIW, most guys I know run wider tires on the narrower rims b/c they actually stay attached to the bead seat better than wider rims. I had a friend that ran a 33x14.5" bogger on 7" wide rims....He aired down to 3 psi with no beadlocks and never rolled a bead off. The only downside is crowning the tread more when at road pressure.
Good luck to you. The tires you chose look great.
Take care,
Sean
Old 03-26-2006, 06:51 PM
Just a warning.
Sean
You are a complete and total ****ing idiot. Now you want to tell people they won't throw a bead at 12psi? Geezus!!!!!! Dude, you have talked out of your ass a little too much here. Why don't you STFU and read a little, maybe you will learn accurate facts and quit spouting the BS that some newbie will believe as truth.
As far as a gauge is concerned, don't use a tire gauge either, it's gimmicky.
It doesn't freaking matter on these trucks if you have 1 person extra or 5. Specs take a lot more than that into account and people's pucker factors are completely different. If the manufacturer says that it will go up to x% slope, then why the &#uck would you not get a gauge and figure out where that is.
Just damn. How old are you? Do you even have driver's license?
Old 03-26-2006, 07:06 PM
Again, your inability to comprehend the written word has caused you to fly off the handle. The surest sign of someone with no rational argument is when they resort to name calling.
I can back up my point, but I refuse to do so with someone who's acting like a child. Why do you think I haven't been responding to your other posts? I can assure you it's not b/c I don't have plenty of rebuttals for you.....it's b/c you're not worthy of the time.
When you can have an adult conversation, I'll be more than willing to discuss this with you. Until then, I'm sure you'll continue digging your own grave.
Sean
