Old 12-10-2004, 05:15 PM
H2Beast H2Beast is offline
H2Beast is off the scale
Greetings,
I need help. I'm just about closing a deal on a 4 door H2 04, done 8000 miles. I've got some concerns related to the H1 weak points:
- Upper and lower ball joints on the suspension A arms are too weak.
- Transfer case housing is too weak so is the chain inside.
- Brake pads are sizing on the rotors, especially in the front.
- Steering idler arm likelly to break.
- If CTIS equipped, always leaking.
- On gas engines, the fuel tank is subject to melting because the tank is not enough protected from the exhaust. The fuel creates vapor, the vapor dilates the "plastic" tank to such an extreme that the tank would actually touch the exhaust pipe.
- The gear hub will take a lot of play very fast and is too weak to stand any abuse in the rocks or with bigger tires.
How true all is all this?
Hummer H2 2004, Jeep Wrangler Rubicon 2004, Corvette C5 2004. All modified..Check my website for more info.
Greetings,
Greetings,
Old 12-10-2004, 06:04 PM
JollyRoger JollyRoger is offline
JollyRoger is off the scale
Hmmm.. I have never heard of these problems, someone is giving you some BS.
If anything is undersized, it's H2 components, NOT H1 components.
Oh, and I do extreme wheeling often, and have only broken a halfshaft once, nothing else. Rock crawling, etc, I dunno, I think te guy telling you all that is talking out his ass.
Old 12-11-2004, 05:42 AM
The reason of his statement is that he wants to show people that his own UAE built concept car is outperforming the H1. Check the guy's website and see his statement here below:
(this is a copy if Jon's post on my forum)
Al Dhabi and its brothers (see www.advancedmodularvehicles.com) are UAE made, are not a copy of existing vehicles, do not get any engineering input from overseas and are build for the sole purpose to be the most reliable and performant desert vehicles in their classes and applications.
Al Dhabi specs are on the web site. It beats the H1 in 95% of the positions. If you are interested, I have a video of the H!-Al Dhabi comparison. You can see it but you cannot have a copy for obvious reasons.
H1 have the following weak points:
- Steering idler arm likely to break.
Please note that most of these weak points are related to the civilian version only. The military versions are not exactly build the same way....
How do I know ? I was the GM of the Hummer dealership in Lebanon for 6 years and I have driven 4 door pick up and a 4 door wagon for over 3 years.
In reference to your H2 with 40" tires, be careful, The front and the rear differential are far weaker as the Dana 60. They are just about taking the abuse of the 35" tires. In the sand, no problem. In the rocks, you are likely to break a shaft after a few tuff outgoings.
Old 12-11-2004, 12:02 PM
Shawn from Angry Iron Shawn from Angry Iron is offline
Shawn from Angry Iron is off the scale
Check out my website www.angryiron.com go to the pictures page for some good wheeling pictures.I have never broken anything on the trail. Knock on wood.
Sounds like the guy is a BozO.
You can go to www.flashoffroad.com for excellent articles on buying a used H1. Good Luck buy it you will like it!
Shawn
85 HMMWV
Angry Iron www.angryiron.com
Taking the High Ground
Old 12-11-2004, 01:40 PM
ckhagman ckhagman is offline
ckhagman is off the scale
The ground clearance is definitaly not that of an H1. Sure it might look it but with a straight axle with the same tires it is still a little lower. I would like to see some real specs. The specs listed are great but fail to tell you the whole story of the truck.
As for the weak points of the H1.
-Same as military
- not sure but might be the same as the military
- I have never had this problem
- Same as military
- SO WHAT. how many cars have have this option. If it leaks at least you have something that others don't. Mine has been leaking for months but who cares.
Same as the military.
http://www.penta-nut.com
The Most Sirius Off-Road Vehicle
Old 12-11-2004, 06:15 PM
Thanks guys.. Thanks for the link Shawn, great site.. and I will be posting some pics once I get my deal done. Guess what the AMV guy asked for a tuff Dahbi vs H1 hard core offroad drive. I will keep you posted
Old 12-11-2004, 10:44 PM
Beastmaster's Avatar
Beastmaster is off the scale
Hmm..interesting viewpoints. My replies in bold below.
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by H2Beast:
Greetings,
I've never seen a blown out ball joint yet. Most ball joints can handle 75k miles or more without problems.
It all depends on how you drive. If you have lockers on it, you'll likely never have chain issues in the NP242. If you BTM a lot, you'll eventually have chain stretch - in about 100k miles.
Brake pads seize due to poor maintainence. Either the brake proportioning valve, the master cylinder, or brake booster is going out.
I've never seen an idler arm "break". I have seen old style idler arms wear out and need replacement. I've yet to see the new Moog parts wear yet.
Again - poor maintainence. If your CTIS is maintained properly, you'll have zero issues.
No Gas engined Hummer owners have ever reported this issue. That's BS.
Nope. I run 38.5" Interco Tires with zero issues. People also run 40" MTR's and also have zero issues. The geared hub is very, very strong. More BS.
How true all is all this? <HR></BLOCKQUOTE>
M101A2 Trailer
