Old 10-15-2006, 04:14 AM
tomp's Avatar
tomp tomp is offline
Default Why did I not have front wheels spinning?
I got high-centered this morning. Was in low-locked and only the back wheels were spinning.
I was going uphill and high-centered as the front wheels went over the top. There was plenty of force down on the front suspension and I could have really benefitted if the fronts were spinning as well. Why does this happen?
Old 10-15-2006, 12:08 PM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
Default Re: Why did I not have front wheels spinning?
Transfer case in 4 Hi, not 4 locked. Locked forces the front to spin with the rear. 4 Hi directs more power to the rear 60% (i think).
Old 10-15-2006, 02:17 PM
If you are in four wheel HI mode, the traction assist system applies the brakes to the spinning tires to allow all engine power to the other wheels. Spinning tires give no traction.
Old 10-15-2006, 03:12 PM
Dug Dug is offline
Dug is off the scale
DO you know if the fourwheel drive was working before you noticed the front wheels were not spinning?
When you was in low lock, are you sure the tire on the opposite side of what you could see was not turning?
Trying to help narrow down the possibillities.
Old 10-15-2006, 04:23 PM
tomp's Avatar
At part throttle, nothing was spinning. Then, when applying more throttle to make it over the top, the rear would break loose and spin. Fronts never would move while rear was spinning as both fronts were on the ground and I was sitting still.
Only way to make it over was to reverse and build up some forward momentum.
Also tried slightly mashing the brake during throttling and that did not do anything
Old 10-15-2006, 05:08 PM
tomp's Avatar
I will have to try this move again next time I'm out. However, it did happen several times over this weekend.
Any idea what keywords I could search on to bring up those threads that show each mode? IE, TC, TC2, 4x4 hi, 4x4 low, and 4x4 low-lock?
Old 10-15-2006, 06:05 PM
i don't want you to think I'm implying you don't know what you are doing, but are you 100% positive it was in 4lo locked. I have seen people push the button while moving and the light flashes but does not engage.
It's possible the light can be solid also and the T Case is not engaging. I've seen this on two trucks to date.
Did you BTM while in 4 LO Locked? If so, were you turning the stering wheel back and forth? Sometime this will give the truck a slightly different angle since it had most weight on the front and cause one of the front wheels to spin.
you may want to follow up with the dealer if you have one close by to check out your T case and to see that everything is engaging properly.
Good luck,
Tim.
Old 10-15-2006, 08:20 PM
tomp's Avatar
Tim, 110% sure it was 4-wheel low-locked. There is no mistaking it. Changed into that mode in neutral while stopped and did this each time before encountering the uphill climb. Each time it did the same thing.
Old 10-15-2006, 08:38 PM
ShortBus's Avatar
ShortBus ShortBus is offline
ShortBus is off the scale
My front driver tire tore into the wiring loom that runs on the frame at the back of the tire. This caused some electircal problems that included the transfer case not getting the signal to engage. If you have been doing any heavy articulation, I would check it out. If this is the problem, don't be afraid to tape'em back together. The dealer charged me $100 bucks to do mine and it looks like crap.
Old 10-15-2006, 08:43 PM
Hummie2's Avatar
Hummie2 Hummie2 is offline
Sounds like a serious T-case problem. Could be a broken lockup shiftfork not letting the T-case go into lock mode. The shift motor turns the shifter cam and the encoder shows that it shifted, but nothing happen inside the T-case to shift the gears. Was the front driveshaft turning when you noticed the front wheels weren't spinning?
Old 10-15-2006, 10:53 PM
tomp's Avatar
Not a wireloom problem
Hummie2, I need to check the front shaft next time I am out. More than likely it was not spinning, but still good idea
Old 10-15-2006, 11:58 PM
Dug Dug is offline
Since your 110% positive its in low lock (as in you could feel it was in low gear when driving ahead. ) It sounds like there could be a transfer case problem. Do you know if you have four wheel drive in Hi range?
Old 10-16-2006, 01:53 AM
tomp's Avatar
I will try and take some time this week to raise all four off the ground and go through each mode to determine if I get wheel spin.
Old 10-16-2006, 01:58 AM
Are you still uner warranty? How close is the dealer? You may want them to look at it. THey can hook their techh II up to check for issues.
Also, if you have a Hypertech Programmer, plug it in and see if you get any codes.
Old 10-16-2006, 02:34 AM
Dug Dug is offline
tomp - a quicker way than jacking all fours up in the air to find out if your 4wd is working. Is to go out in some dirt , put it in reverse and floor it. You will now if the four wheel drive is working.
Old 10-16-2006, 09:37 PM
tomp's Avatar
Wanted to clarify to everyone, that I did have the rear e-locker enabled during that time. Not sure if this makes any difference to what I was experiencing or not, but did want to bring it up just in case.
Old 10-17-2006, 08:55 PM
Hummie2's Avatar
Tom, here is what you do:
1)If you have a floor jack (trolley jack) go out in the driveway and raise both rear wheel off the ground slightly. (about an inch or two)
2) get in and start the truck, shift to 4lowlock, apply the brakes lightly (just enough to illuminate the brakelights. This will disable Trac Control)
3) shift the transmission into gear and see if you can move the truck slowly with the rear wheels off the ground.
Does the truck move? If yes it went in lock ok. If no, does the front driveshaft spin? If the front driveshaft doesn't turn then the T-case isn't locked (all power going to rear axle only). If the driveshaft does turn and the halfshafts & wheels don't, then the problem lies in the frontend. (broken axleshaft, spidergear,etc.)
Being able to lock the rear E-Locker shows that the T-case motor encoder signaled T-case shift module that the shift to 4lowlock was completed, but did gears actually move to 4lowlock inside the T-case? (broken shiftfork)
