Old 09-27-2006, 06:33 PM
sc2178's Avatar
sc2178 sc2178 is offline
sc2178 is on a distinguished road
Default adding an amplifier to the Monsoon sound system - where to connect
Where is the stock amp located? Does it have an RCA output on it?
If not, where can I find a wiring diagram to tell me which speaker wires are which colors?
Thanks!
Old 09-27-2006, 06:43 PM
Default Re: adding an amplifier to the Monsoon sound system - where to connect
The amp is in the driver side rear panel next to the sub.
Not a stereo guy so can't answer the rest.
Old 09-27-2006, 07:12 PM
sc2178's Avatar
So it is easily accessible? I don't even have my H3 yet (this weekend) but I want to be prepared
I CAN'T WAIT by the way
Old 09-27-2006, 07:52 PM
Can't say for sure since I've never removed mine, but I'm guessing its probably pretty easy to remove the panel.
Old 09-27-2006, 10:05 PM
Pull away the top panel slightly, then pull the bottom panel away from the vehicle. Make sure to lower the rear seat back. It can be tricky getting it out with the rear seat still in place, but not impossible.
Remove the rear seat does make it a lot easier.
Upon installation, just pop all the fasteners back into place and don't forget to place the outer sealing strip back over the back edge of the molding.
Old 09-29-2006, 01:49 PM
sc2178's Avatar
Thanks! Is there by any chance an RCA pre-out on that amp? If not, do you know where I could find a list or diagram of the wiring back there?
Old 09-29-2006, 02:11 PM
I would say that there is next to no chance of any pre-out since it is a factory amp. I know I came across a wiring color code a while back, let me see if I can find it.
Old 09-29-2006, 03:16 PM
kodiakz kodiakz is offline
kodiakz is off the scale
Oem amps never have any rca outs on them; you will need to grab sets of speaker outputs from the Monsoon amp and run those into a high to low level converter. I would recommend the Soundgate LOC1.
Old 09-29-2006, 03:58 PM
sc2178's Avatar
Yeah I figured, but didn't know what you might find in these new cars
I have a level converter already, just need to know the wiring color codes for which wires to tap into
Old 10-18-2006, 10:54 PM
Klint's Avatar
Klint Klint is offline
Have we figured anything out yet? I am wanting to add a 10 or a 12 to my H3. I have the monsoon system in with the Fact. 8' sub....
Klint T.
2007 Black Lux, Blinged out
Old 10-21-2006, 11:55 PM
Klint's Avatar
anyone?
Klint T.
Old 10-25-2006, 05:44 AM
Klint, there is nothing to figure out!! lol Tap into any of the speaker leads with a high to low converter for signal, any ignition lead for turn on, and a 12v battery lead and you are good to go.
Old 10-27-2006, 02:47 AM
Klint's Avatar
What is a low to high converter?
Klint T.
