04-06-2006, 10:23 PM
hi i was wondering if anyone knew what the different color wires comming out of the back of a 04 stock navagation radio are? i need to know what is power / ground / and so on... thanks!
04-06-2006, 11:45 PM
12v constant is orange and black (on the oppisite side of the plug) is ground. There is no switched power at that plug. What other wires do you need identified? What are you trying to install?
04-06-2006, 11:57 PM
hi i am trying to install a separte dvd player/headunit.. were the onstar is located.. im gonna move that... and keep the factory navagation/headunit and just use it for nav only.. i just need to hook up a new head unit below. so i would need.. power .. ground.. and extend the fm antenna.. that might be it.. any suggestion i appericate it..!
04-07-2006, 01:00 AM
Onstar is behind the glove box. Are you going to use the new unit for sound or just video? You will have a very difficult time retaining the oem head unit and adding a second head unit to share the same amp/speakers and don't forget about the databus.
04-07-2006, 01:50 AM
i am going to move the onstar buttons under the temp control. the ones in the center.. and put a dvd/headunit in that space.. i aready replaced all the factory speakers.. and added 2 jl amps.. but i figured it would cost a couple hundred dollars for the adaptors. to use the factory headunit for my main stuff. instead i was going to put that money toward a new headunit that could also play dvds...and have a aux in and better sounds quality.. and keep the factory one just for the navigation.. so i really dont even need speakers hooked up to it.. just one small one for the navagation lady..voice... dose that make sense..? thanks for your help
04-07-2006, 03:29 AM
Radio-C1
Connector Part Information
12110088
24-Way F Micro-Pack 100 Series (GRY)
Pin
Wire Color
Circuit No.
Function
A1
ORN
1044
Radio Class 2 Serial Data
A2-A7
Not Used
A8
TAN
511
Left Front Low Level Audio Signal (+)
A9
DK GRN
1947
Left Front Low Level Audio Signal (-)
A10
BLK
1946
Right Rear Low Level Audio Signal (-)
A11
DK BLU
546
Right Rear Low Level Audio Signal (+)
A12
BLK/WHT
1851
Ground
B1
ORN
340
Battery Positive Voltage
B2
Not Used
B3
GRY
161
Antenna Preamplifier Supply Voltage
B4-B7
Not Used
B8
BRN
599
Left Rear Low Level Audio Signal (+)
B9
DK GRN/WHT
1547
Left Rear Low Level Audio Signal (-)
B10
ORN/BLK
1546
Right Front Low Level Audio Signal (-)
B11
LT GRN
512
Right Front Low Level Audio Signal (+)
B12
Not Used
Radio-C2
12064799
12-Way F Micro-Pack 100 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A-K
Not Used
L
ORN/BLK
2061
Cellular Telephone Voice Low Reference
M
PNK/BLK
2062
Cellular Telephone Voice Signal
Rear Seat Audio (RSA) Controller
12110206
24-Way F Micro-Pack 100 Series (LT BLU)
Pin
Wire Color
Circuit No.
Function
A1
LT BLU
2288
RSA Class 2 Serial Data
A2
ORN
340
A3
Not Used
A4
BLK/WHT
1851
Ground
A5
Not Used
A6
BRN
1547
A7
BLK
1946
A8-A12
Not Used
B1-B5
Not Used
B6
BRN
599
B7
DK BLU
546
B8-B12
Not Used
1998 Chev Z71
2007 Chev Trailblazer SS
04-07-2006, 09:27 AM
thanks!
04-07-2006, 12:04 PM
Well, I have never tried it, but I don't know if you can get any speaker output from the oem nav unit--I believe it is all preamp signal but wouldn't hurt to hook up a test speaker and give it a shot. However, you may need to run the signal through the oem amp to get the nav voice on an outbaord speaker. Why not just get one new unit that does dvd, nav, music, ipod, etc and sounds better? Would work better and save you a lot of hassles!!
