  #41
Old 10-28-2006, 04:57 AM
DURAMAX TIM is off the scale
Default Re: Rear E-Locker
Originally Posted by HummBebe
TC 1 = 4hi lock ?
TC 2 = 4lo lock ?
TC 1 is standard
TC 2 allows wheel spin and keeps the brakes from slowing the spinning wheels for mud and snow.
I always used e locker and TC2 in 4 low so don't know if TC2 worked in HI lock or open.
I just don't want TC to slow the wheels down when u need the wheel spin and the e locker is going to keep the rear tires same speed so the TC won't slow one rear wheel if it's turning faster because it has a little less traction.
will the e locker work in 4 hi in the H3?
98 ZR-2 Blazer
Ex H2&3 owner
Old 10-28-2006, 05:20 AM
fw888's Avatar
fw888 fw888 is offline
where is the traction control ? i know there is only a button for stabiliztrack on the control panel..
06 H3 Boulder gray,
Adv. Pack, Chrome Pack, Chrome Step Assist, Chrome fuel cover, Chrome Hood with handle, Chrome air intake, Chrome side marker light, Oem Brushguard, Tow Package, Factory Mudflaps Front/Back, XM Radio, OnStar ... more to come
Old 10-28-2006, 06:03 AM
No. It will disengage at 20MPH.
So can you go over 20MPH in TC 1?
Old 10-28-2006, 06:05 AM
That is because the Traction Control system is always on. You cannot turn it off.
Where is it? In the puter
Old 10-28-2006, 05:02 PM
Wow, strong opinions either way - I don't know what the right answer is, but I will add it is very difficult to design a traction system for all surfaces.
The TC switch shuts off both the stability and traction systems.
There are two wires going to the e-locker: light green and black (I think these are the colors). +battery is switched to the light green wire and the black wire returns to the transfer case shift control module where it connects to ground through a resistor/current limiter. The final circuit will be pretty simple but you need to do serveral tests first to understand what is inside the control module.
For example, you'll need a diode to clamp the inductive current for the e-locker coil to prevent an insulation breakdown when you interrupt coil current.
Old 10-28-2006, 05:13 PM
TC Switch?
Old 10-28-2006, 07:13 PM
Sorry, I wasn't clear - Traction Control System - TCS switch.
Old 10-28-2006, 07:46 PM
On which model H2 or H3?
If H3, what switch are you referring to?
Old 10-28-2006, 08:22 PM
I was refering to the H3. This is the rightmost switch - picture of a car with squiggly lines underneath it. Hold it in for 5 sec and this will disable the traction control and the stability system (if you have it).
Old 10-28-2006, 11:21 PM
That is the stabilitrac switch. Different system than the traction control.
You cannot turn off the traction control
Old 10-28-2006, 11:27 PM
yzergod's Avatar
yzergod yzergod is offline
yzergod is on a distinguished road
You are incorrect sir/maam ()... there is a switch on the column... the ignition switch! That will turn off the traction control. But I don't think it's useful over 5 mpg (I could be wrong )!
"Now remember, things look bad and it looks like you're not gonna make it, then you gotta get mean. I mean plumb, mad-dog mean. 'Cause if you lose your head and you give up then you neither live nor win. That's just the way it is."
Old 10-28-2006, 11:42 PM
Sir????
You =
Old 10-29-2006, 02:18 AM
Here are two pages from the owners manual. You can get the electronic owners manual from www.mygmlink.com after you register.
Old 10-29-2006, 02:21 AM
fourfourto's Avatar
That sure explains it
Old 10-29-2006, 03:05 AM
so lets see, we turn OFF the TC/SC when in mud and snow or it will limit wheel spin which may get u stuck.
Now the e locker kicks out over 20mph, so if play off road in muddy or snowy conditions we just have to keep the speedo under 20mph
I know I've hit a lot more than 20mph in mud pits and snow drifts not to mention slippery hills.
I still want my elocker to stay on when I turn it on.
98 ZR-2 Blazer
Ex H2&3 owner
Old 11-02-2006, 02:11 AM
***crickets****
now what?
98 ZR-2 Blazer
Ex H2&3 owner
Old 11-02-2006, 02:45 AM
SR1355's Avatar
SR1355 SR1355 is offline
Paul M
SR1355
Old 11-02-2006, 11:52 PM
I made the mistake of not getting the off-road package so I can't just try this on mine. How about this. With the key off, disconnect the connector from the e-locker. Measure the resistance from the black wire (going to the control not to the e-lock coil) to a good ground as close to the control as possible. Zero out the probe resistance first.
Old 11-03-2006, 04:27 AM
Hal's Avatar
Hal Hal is offline
Hal is off the scale
I have the service manual and pages 4-150, 4-156, 4-160 explain the following respectively: Differential lock schematics, Circuit Description, and Electronic Diff Lock Will Not Disengage troubleshooting. I wish I could post this and have it be readable or be able to explain it. (I'm a Pharmacist not an Electrical Engineer) if anyone else can post this info for ChevyHighPerformance to look at we might have an answer.
Shadow Green 5-Speed/GREEN GRILLE/rear door AIR compressor/Factory Nav/Lux-Off Road Pkg/Sunroof/Roof & Grille Off Road Lights/Underbody Protection/Wet Okole seat covers/Husky floor liners/Black fuel door/No Chrome/'04 Grand Cherokee Overland/'94 Isuzu Rodeo 4x4 lifted.
Old 11-03-2006, 04:47 AM
H3PAC's Avatar
H3PAC H3PAC is offline
Originally Posted by Hal
I'm a Pharmacist not an Electrical Engineer.
Damn it Jim!
