Old 11-02-2006, 11:13 PM
H2 rocks me H2 rocks me is offline
H2 rocks me is off the scale
Default Will the plane takeoff?
A plane is standing on a runway that can move (like a giant conveyor
belt). This conveyor has a control system that tracks the plane's
speed and tunes the speed of the conveyor to be exactly the same (but
in the opposite direction) instantly.
Will the plane be able to take off?
Old 11-02-2006, 11:18 PM
Default Re: Will the plane takeoff?
Yes.
Old 11-02-2006, 11:24 PM
No. The plane is "standing".
Or:
No. The plane isn't moving.
Old 11-02-2006, 11:28 PM
Depends on the plane.
The tires might blow due to the speed.
Old 11-02-2006, 11:29 PM
Or:
be able to
Old 11-02-2006, 11:43 PM
BlueTJCO's Avatar
BlueTJCO BlueTJCO is offline
it would take off. just think physics, F=m*a. The forward force (from the thrust) in both case is always bigger than the backward force (due to the friction of the wheel and ground, and it's very small compare to the thrust force), therefore the net force is always forward. So the plane will accelerate forward in both cases and take off.
Next Please
Old 11-02-2006, 11:44 PM
BlueTJCO's Avatar
Thats the correct answer. At 500mph the tires would blow for sure... Aircrafts average take off speed is 120 MPH I think.......
Old 11-02-2006, 11:50 PM
Mrs.ssippi's Avatar
Blue? No, no the answer is yellow. Yes, yellow and that is my final answer. Wait, can I use my phone a friend?
Old 11-02-2006, 11:51 PM
How do you figure the plane can take off when there is no wind moving over the wings to create lift? Can't happen.
Old 11-02-2006, 11:53 PM
BlueTJCO's Avatar
what do you want to bet?
J/K..........Damn, this question gave me a headache like 3 years ago when it originally popped up on the internet........
Old 11-03-2006, 12:10 AM
X2 Unless it's a Harrier.
Old 11-03-2006, 12:23 AM
Atlanta, Georgia.
Old 11-03-2006, 12:25 AM
Wisha Haddan H3's Avatar
Yes for self-propelled airplanes but No for gliders towed behind ground vehicles.
In self-propelled airplanes thrust is delivered from the props or jets directly to the air, not to the ground. Since no forward thrust is delivered through the wheels, the conveyor will remain stationary. In fact, the conveyor may even move forward slightly with the plane depending on the amount of friction from the axles and the tire's contact patch. As the plane moves forward through the air, relative airspeed increases, lift is generated on the wings and the plane takes off.
With gliders, thrust is provided by a tow vehicle. If the tow vehicle is a truck on the conveyor, it would deliver its thrust through the wheels to the conveyor. Forward movement would be negated by the conveyor's movement, resulting in zero forward motion. The truck could be going 100 mph (relative to the conveyor) but its airspeed and groundspeed (next to the conveyor) would still be 0. No air would pass over the glider's wings and no lift would be generated for takeoff.
Old 11-03-2006, 12:32 AM
Mrs.ssippi's Avatar
Atlanta, Georgia.
That is not the answer it is yellow!!!!!!!!!!!!!!!
Old 11-03-2006, 12:33 AM
Nope
keep trying
Old 11-03-2006, 12:38 AM
Yellow is always a good answer.
Old 11-03-2006, 12:40 AM
Four?
Old 11-03-2006, 12:46 AM
X2
Old 11-03-2006, 12:56 AM
True that a plane can't take off w/o airflow over the wings to generate lift.
So the underlying question is ... "can a plane generate forward motion (into the wind) on a runway that moves in the opposite direction?"
A car could not, because it generates forward motion by transferring energy to the ground, which would be negated by the conveyor's opposite motion. But a self-propelled plane could still move forward, because it accelerates by pushing the air, irrespective of ground speed or conveyor direction.
Old 11-03-2006, 12:59 AM
But a self-propelled plane could still move forward, because it moves forward by pushing the air, irrespective of ground speed or conveyor direction.
Doesn't the conveyor prevent the plane from moving at all? If so, no movement of air over the wings, no lift.
