Old 11-07-2006, 03:20 AM
Matt19's Avatar
Matt19 Matt19 is offline
Matt19 is off the scale
Default offroading
guys silly question, but still I need answered. Last week I was trapped in a crowd of people, and the only way out was a nice hill that my h3 can easily scale. It was more of a test offroading experience. What I like to know is what are the meaning and differences of all the 4wd options.
what is the up arrow lock mean and down arrow lock, (low lock, high lock?) and when should they be used. Mud? uphill? down hill?
Funny thing is, I asked the firemen and officer there if i could go up the hill, it wasnt an even hill. It was a little rocky, and jagged. But they said "if you think you can, go ahead" but they didnt know i had a hummer. They just stood there and watched, just in aww. It wasnt even hard, i need more of a test now.
2007 Black H3, Adventure Package, Chrome Appearance, Chrome Cross Bars, Moonroof, Tow Package, Chrome Tubular Assist Steps. "My golly, this is by far the best looking 2007 H3 you will ever never witness"
My H3 is gods gift to man.
Old 11-07-2006, 03:37 AM
Big Z Big Z is offline
Default Re: offroading
ALL That STUFF Means!....READ YOUR MANUAL!!!
Old 11-07-2006, 03:38 AM
Matt19's Avatar
ok
Old 11-07-2006, 03:51 AM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
Matt, yes you do need to read the manual but I'll try and summarize it a little bit for you...
4High open is what the truck runs in all the time.
4High lock is a mid speed range where 50% torque is sent to the front diff and %50 power is sent to the rear diff and all wheels are locked in spinning at one speed.
4Low Lock is for severe off roading and if you have a auto trans it should be in low 1. This gives you the most torque to crawl over obstacles. It's a very slow speed given to you from the transfer case. You shouldn't go over 10-15 mph in this setting.
For instance, if you were to run in some sand dunes or something like that you would run in 4 high lock and drop the shifter into 3rd gear and have at it!
If you were climbing some rocks or up a very steep hill, drop it into 4 low lock an put the shifter in low 1. This way you will crawl right up the hill or rocks.
Not knowing what this hill looked like that you went up it's hard to give you advise as to what 4 wheel drive option to use. From what you said it doesnt sound to hard.
But yes, time to get out the owners manual and read about your 4 wheel drive options. You certainly don't want to be embarrased if you get stuck because you didn't have the truck in the correct 4 wheel drive setting.
____________________________
Old 11-07-2006, 03:53 AM
DAMNIT AND WE CAN'T EDUMCATE OUR KIDZ!
Old 11-07-2006, 04:24 AM
Matt19's Avatar
thanks, yeah i'll get right on that manual reading.
Old 11-07-2006, 03:55 PM
this is how i decide , in sand and terrain when you want to go 15 mph or faster just use high lock . steep stuff , rocky or just want to go real slow use low lock . when in low lock i very seldomly ever need more than second gear . my rule is if you want more speed than second low go back to high range . before flaming there are times i use 3rd in low but not many . and there are lots of times to just keep it in 1st low lock . as you wheel more you will see how the truck works in different situations and soon you will know what you need before you get there . the rear locker is great to get over a tough spot but unlock it as soon as you have completed it .
Old 11-07-2006, 08:46 PM
what is this the Dr. off-road show
Old 11-07-2006, 08:47 PM
HELLOVA lot better the Dr. Phil...
RYD
Old 11-07-2006, 10:25 PM
LMFAO
Old 11-07-2006, 10:31 PM
RYD
X2 Pops
Old 11-11-2006, 03:33 AM
Alan06SUT's Avatar
4High lock is a mid speed range where 50% torque is sent to the front diff and %50 power is sent to the rear diff and all wheels are locked in spinning at one speed. First part is right but, the wheels are not locked in at this point (not 25% power to each wheel), basically 2 wheel drive one up front one in rear if either axles looses traction.
4Low Lock is for severe off roading and if you have a auto trans it should be in low 1. This gives you the most torque to crawl over obstacles. It's a very slow speed given to you from the transfer case. You shouldn't go over 10-15 mph in this setting. Same situation as 4Hlock, but the gearing is much lower as stated.
Also, you didnt mention the Locker option. I dont know if your has it, but the locker will split the 50% of power going to the rear axle into 25% going to each wheel of the rear axle, basically you will have a three wheel drive, 25% at each rear wheel, and 50% to one of the front tires if traction is lost. To get a true 25% distribution of power to each wheel you would have to install a front locker.
Also the H2's t case splits the engine power 40% to the front and 60% to the rear. I am assuming the H3's T case splits it 50/50???
One other thing is the traction control system. If it senses one wheel of an axle is spinning, it will hit the brakes on that wheel which, sends the power to the other wheel on that axle. Its not quite as effective as a true locker, but is much better than an open differential or a limited slip, which will send all power to the wheel that has the least resistance if the other wheel on that axle is stuck.
WHEW, Sorry.
Think of it like this (when traction is lost by all wheels this is the number of wheels that will be spinning):
4Hi = 1 wheel drive
4HiLock=2 wheel drive
4LoLock=2 wheel drive with more torque
4LoLock w/ Locker=3 wheel drive/ more torque
Add front locker:
4LoLock w/ rear locker and front locker=4 wheel drive
Old 11-11-2006, 04:54 AM
marin8703's Avatar
WHEW, Sorry.
4Hi = 1 wheel drive << Are you sure about this part?
Add front locker:
I though that in 4Hi there is a power split of 40/60 or 60/40, which ever it is. So wouldnt that mean that there would also be "2 wheel drive" with 4Hi, just as in 4Hi Lock, except that in 4Hi the power split will not be 50/50 but will be 40/60 or 60/40? I dont think that you can have power sent to only 1 wheel, no matter how many looses traction, i guess 2 would be the minimum (several possible combinations). Could be wrong.
EDIT: Oh and on that last note you made, anyone know if theres a front locker for the 3? Anyone have one installed? How much do front lockers usually run?
Sorry bout the question.
