Old 04-08-2006, 09:44 PM
Plano H2 Plano H2 is offline
Plano H2 is off the scale
Last night my wife called me when she was on the way home. She stopped about a mile from our house at the gas station and said the H2 was smelling like burning rubber. I met her there and inspected the truck in and out. The engine sounded fine, etc. So I slowly began driving it home and there is a noise coming from under that sounds like most cars sound when driving in reverse. You can hear the gears. After a block or so, I started smelling the same thing she smelled. I was almost home so I went ahead and brought it home and parked it. Has anyone ever heard of this problem or have any ideas of what the problem could be?
Old 04-08-2006, 10:02 PM
VTSTOMPER is off the scale
Did you mess with the trans? I think it's toast...or your transfer case it shot. Try some different gears....and going from 4 high to 4 low - either way it is going to need to make a trip to the dealer. Could you have been smelling a clutch burning smell? It smells like when you are behind a semi and their breaks are dragging.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 04-09-2006, 12:28 AM
Motohead's Avatar
Motohead Motohead is offline
you sure she didn't run over a VW Beetle and got it stuck under there? I hear they make a grinding noise when dragged under a H2.
Old 04-09-2006, 04:02 AM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Originally posted by Plano H2:
The H2 was smelling like burning rubber. I started smelling the same thing she smelled. Has anyone ever heard of this problem or have any ideas of what the problem could be?
Hmmm ... maybe to many Bacon Bean Burritos?
Parking brake on?
Old 04-09-2006, 11:37 AM
another poor Prius gobbled up
Old 04-09-2006, 03:20 PM
Screeper's Avatar
Screeper Screeper is offline
Screeper is an unknown quantity at this point
power steering pump going bad? Check fluid fore burnt smell...
Old 04-10-2006, 12:14 AM
I am taking it to the dealer tomorrow. I just cannot figure it out myself. I will report back.
Old 04-10-2006, 03:14 AM
Make sure you do report back. I'm watching you.
Old 04-10-2006, 12:54 PM
The hummer dealer said maybe I left it in 4 high lock so I confirmed it was in normal 4h. they are towing it now and he will call me later.
Old 04-10-2006, 11:45 PM
Ok. I heard back from the dealer. The front diff seal was broken and much of the fluid had drained. He was inspecting it for damage. He said whoever was doing my oil changes should have noticed it. But, they didn't. fortunately, it is still under warranty.
Old 04-10-2006, 11:46 PM
Oh, and to add to my pleasure....the tow truck dropped oil, not mine, on my perfectly clean circle driveway in like 5 spots. anyone know how to get it up?
Old 04-11-2006, 04:22 AM
Yeah, call them and tell them to do it! Or try Muratic acid in a weak mix with water.
Old 04-11-2006, 12:18 PM
Dawn takes the grease away
Super Clean by Castrol
Dry cement mix
Mean Green
Carb Cleaner
Old 04-11-2006, 12:43 PM
JohnB.GWU. JohnB.GWU. is offline
JohnB.GWU. is off the scale
that sounds like a personal problem...consult the mechanic that works on your body
John R. Benda
03\' Yellow Adv- Sold
04\' White H2 Lux - Sold
05\' Yellow Lux - BACK TO YELLOW BABY!!!
04 S55 Benz w/Brabus Tuning
Old 04-11-2006, 09:25 PM
Alan06SUT's Avatar
Pour gasoline on it, then wash it all away.
