  #41
Old 11-10-2006, 03:58 AM
Wisha Haddan H3's Avatar
Default Re: My key is stuck in the ignition switch
omg, not again. I would be so pissed if I were you. Good luck!
Old 11-10-2006, 10:44 AM
Okay, semi-good or almost completely good news. It is morning here, and being able to see better it turned out to be mini fuse #9 (15A). Therefore, if your key sticks, the sun roof doesn't work, and wipers don't -- check this fuse.
The only remaining question I have is what fuse the SMA roof light bar uses. It has a 10A fuse, and I think it should be larger. (You can see this fuse in the picture above. It is the large blade fuse at the top-right not in the fuse box.) I have the question still outstanding with the Texas dealer who installed the bar for me.
Old 11-11-2006, 04:42 AM
PCBeach PCBeach is offline
PCBeach is off the scale
Jan 18, 2006..2006 H3 w 7474 miles..
Key stuck in ignition., passenger window would not operate, windshield wiper not work.
Replaced RAP/Accessory Relay #88
No trouble since.
2006 White/Black Hummer H3
2001 Red/Oak Corvette Coupe
