Old 11-24-2004, 07:48 PM
HummBob's Avatar
HummBob HummBob is offline
I'm either going to High Polish or Chrome my front Skid Plate.
I've seen some finished Polished ones on e-Bay and they look SWEET
I'm not sure of the longevity of either process. Has anyone doen this? Polish vs. Chrome - Pros/Cons
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
HummBob's Avatar
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
HummBob's Avatar
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 11-24-2004, 08:04 PM
Big Jag's Avatar
Big Jag Big Jag is offline
Big Jag is an unknown quantity at this point
Definitely polish it, not chrome plate. Polishing is much cheaper and looks just like chrome. Chrome plating on aluminum doesn't work very well and it tends to flake off. Have Bright Lee polish it, it will cost about $160 plus the cost of shipping. He is on ebay and advertises on this website. He did mine, it looks great and has held up well so far. Here's a pic, but it looks just like his ad.
Big Jag
05 H2 (sold)
Old 11-24-2004, 08:09 PM
HummBob's Avatar
Thanks Big Jag. Looks AWESOME! Skid Plate so Bright, Gotta Wear SHADES!
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 11-25-2004, 04:16 AM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
Polishing is the way to go!
Unless you go the way I went. Mud Coating!
Ric-H2
www.meatspin.com
Old 11-25-2004, 04:22 AM
JMV1210 JMV1210 is offline
JMV1210 is an unknown quantity at this point
Chrome, after a year it will look like it was never touched. It may keep for a bit longer if you maintain it. Talk to NJH2, he had his polished Nov 2003. Needs to be done again. If you chrome it, it will keep for a much longer time.
Old 11-27-2004, 03:47 AM
Bright-Lee's Avatar
Bright-Lee Bright-Lee is offline
Bright-Lee is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> Aluminum is a relatively soft metal and is somewhat porous. If you happen to read about the gas cap with the chrome peeling due to vapors trapped underneath (another topic here in the Forum), that is a typical problem. However when I saw the back of the cap, it looked as if there was possibly machining oil still present when it was plated, another common problem.
More problems, in many cases, are due to the shape of the part to be plated.
Imagine chrome is like metal dust. If you were to sprinkle this metal dust over a magnet shaped like the letter “V”, the dust will cling to one side or the other and never make it to the bottom. This problem is overcome by making what is called an anode.
Anodes are lead bars connected to the positive electric pole and strategically placed to activate the plating process. Anodes aren’t always used where they should be because of the lengthy process required to set them up. This results in poor coverage in cracks and corners.
Since aluminum expands and contracts much more than chrome, under even mild temperature changes, the results are stress cracks that allow the weather to enter and do further damage. This is the primary reason for even the best of work that’s gone bad.
In regards to chrome over steel, well that’s a whole separate set of pros & cons.
I hope this wasn’t too boring and maybe even answered a question or two.
To everyone who has trusted me to polish his or her skid plate, I thank you very much! And Jason, thank you—this site rocks! <HR></BLOCKQUOTE>
