Old 11-14-2006, 06:47 PM
K9sH3's Avatar
K9sH3 K9sH3 is offline
Default Has anyone...
Has anyone installed a aftermarket amp in thier 3, I am putting installing a new system and can not figure where to out the darn amp. Any help?
Old 11-14-2006, 08:09 PM
Idaho-Hummer's Avatar
Idaho-Hummer is off the scale
Default Re: Has anyone...
If you have the monsoon (sp) system why not put in the that amps place of the monsoon amp if its small enough.
Old 11-15-2006, 03:23 AM
K9sH3's Avatar
I wish I did have that system, where do they have it placed in the 3.
Old 11-15-2006, 06:12 AM
marin8703's Avatar
its in the cargo area in the drivers side panel. Thats where the sub and amp are if you have the monsoon.
Old 11-15-2006, 01:28 PM
J6Niner's Avatar
J6Niner J6Niner is offline
J6Niner is off the scale
k9 - similar issue here. I installed a sub amp a few months back and wound up mounting on the sub box. I hated doing this, but didn't have time to install in the monsoon location. I now have to disconnect EVERYTHING when I need the cargo space. Someone sent me instructions for taking off the rear-quarter panel a while back - believe it was Marin8703??? I never got around to taking it off but would be glad to share the information. PM me your email and I'll send.
2006 Boulder Gray H3 / Adventure / Auto / XM / Side Steps
Previous:
2004 Nissan 350z
2002 Jeep Wrangler Sport
1997 Honda Accord EX
1994 Jeep Wrangler Sport
1980 MGB
Old 11-15-2006, 02:48 PM
Crash ?'s Avatar
Crash ? Crash ? is offline
How big's the amp..?? Physical size if you will... If you want it really hidden, find a way to mount it behind those storage compartment doors.. You may have to do some cutting and fabricating though... If it's small enough you might be able to to put them under the front seats..
I had a 87 Silverado a few years back.. I mounted the EQ and a small amp 50 watt amp for the front speakers in the glove compartment.. Had 2 - 10 inch Fosgate subs and a 100watt Orion amp in a box behind the seat.
I haven't looked at high end stereo stuff in so long I don't even know who the big names are now... Back in 87 I think I placed 2nd in the AR regional Car Wars <150watt cat.. I had a Alpine Cassette head unit, a small 45watt booster amp mounted in the dash with the radio, a 100watt MEI Amp running 2 - 10 inch Pile Drivers with passive crossovers. Sounded decent, right at 100dB, but it was one hell of a clean install. No wiring visable anywhere... The box had been build by a cabinet maker with the sub amp mounted in a cut out on the center. It was built to *fit* behind the seat of an S-10 and I still had room to scoot the seat back most of the way THEN... (A later box with an extra 12" in it had the seat scooted ALL the way forward.. I couldn't even get in the NOW) I had some old scrap red and black vinyl and covered the box with that... At the time everyone else was still covering boxes in carpet if they were covered at all.. I was just to cheap to go spend $35 more for the carpet..
Anyroads.. Be creative with it and you'll figure it out.. And make it look clean when it's done.. Don't leave wires hanging out...
Rob
Old 11-15-2006, 05:58 PM
K9sH3's Avatar
I don't have the monsoon, so that gives me the lil staorage area on the side. I am thinking about cutting the back out and installing in there. It won't fit under the seats. The other idea is building the box (I think JP made a boX) in the rear for storage and put in under that.
Old 11-15-2006, 07:12 PM
Crash ?'s Avatar
Building a box that fills in the back of the truck to put the amp in would work.. Mount the sub box on top of the platform with quick release connectors and wiring disconnects so you can get some of the space back if you need it.. Heck.. If you can figure out a good way to mount the subs in that deck box, fire 'em straight up and still have them protected physically and visually you wouldn't loose much space anytime..
Rob
Old 11-15-2006, 07:56 PM
yzergod's Avatar
yzergod yzergod is offline
yzergod is on a distinguished road
I don't remember where I got this install from, but he had a shop fab up a fiberglass enclosure that fit in the panel/access door location on the rear door. I don't know what he did with his jack. He also removed the driver side panel (where the monsoon amp is located) and installed this giant amp there. It looks like a clean install. HTH!
(These are not my pics, just ones I saved for reference.)
Monsoon in factory location...
New amp mounted...
Sub box in door...
"Now remember, things look bad and it looks like you're not gonna make it, then you gotta get mean. I mean plumb, mad-dog mean. 'Cause if you lose your head and you give up then you neither live nor win. That's just the way it is."
Old 11-15-2006, 08:14 PM
K9sH3's Avatar
Well thanks a heck of alot!!!! Now you just made me want to buy more stuff!!
Just kidding, that is exactly what I needed to see and know.
