Old 11-17-2006, 09:13 PM
H2 Doberman's Avatar
H2 Doberman H2 Doberman is offline
H2 Doberman is an unknown quantity at this point
Default DTC!!!
Does anyone know what this code is "U1301" It showed up on my hypertech today. I also get "B0229" which seems to be a common one because it showed up with the search function. Just curious. The SES light is not on.
Old 11-17-2006, 09:46 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Default Re: DTC!!!
Did you not get the code listing with your programmer?
Old 11-17-2006, 10:16 PM
Default Re: DTC!!!
No, was I suppose to get one.
Old 11-18-2006, 02:13 PM
Default Re: DTC!!!
Thanks phil! I don't think that it is anything terminal. Might just be something that the programmer caused with the battery.
Old 12-31-2006, 03:42 AM
KONG KONG is offline
KONG is on a distinguished road
Default Re: DTC!!!
What is HVAC actuator circuit? because I got the same code too.
Old 12-31-2006, 02:29 PM
Default Re: DTC!!!
B0229 means that at one time your HVAC recirculation door was out of calibration due to a misaligned door or linkage, broken linkage, missing seal, obstruction, or loose wiring connector. If it has corrected itself, the code will go away after 100 ignition cycles, or erased by a scan tool.
