11-23-2006, 08:37 AM
Wheel question 10x16" Rims for H2
Hi,
I have a complete set of wheels 10x16" in 8 lug from a Chevrolet Silverado 2500HD. All dates are the same, but is it possible to install this rims on the H2 because brakes and so on? The tires are 315/75 x16" Mud terrain BFG?s.
Yesterday I have mounted one of the rims on the frontside, it looks great, but the space between brake and rim is only 1/5 inch (0,5cm). Is it enough or can it cause a defect or so?
best Kay
?03 H2 Lux self import from Texas, bit bling
?the best you can do is drive an H2?
11-23-2006, 04:28 PM
Re: Wheel question 10x16" Rims for H2
You might want to have about 1/2 inch for heat build (or small rocks) from the brakes. But dont quote me. I Had a dodge ram 1500 with 15" rims. I never measured the gap from the brakes but I know that its close. I never had problems.
11-23-2006, 06:38 PM
16's will give you major issues!!!!!!!!! Don;t do it.
11-24-2006, 09:03 PM
Hi,
why do you mean it isn?t a good idea? Temperature problems?
11-25-2006, 09:40 AM
Um, I don't see why it would be an issue as long as the calipers are cleared. I have had many rigs with brakes that almost touch the wheel with ZERO issue. I used to build custon rock crawlers and have even ground down calipers (large Dana 60 calipers) to fit a 15" wheel on a 1 ton axle. It was for off road use only of course but it never failed or gave any issue whatsoever. It was within about 1/16th of an inch from the wheel.
I don't think it would be at all an issue to run a 16" wheel on an H2 providing there is adequate clearance from all parts (wheel-caliper-control ams-etc) but personally I don't see why you would do it. Bigger is better for looks IMO
As a matter of fact, I have a set of 16.5 x 9.75 Weld wheels with almost new 38" tires I figured I would throw on the H2 if I ever took it wheeling as to avoid scratching my 20's. If you want 16's, run them, it'll be fine.
MINE - 2006 H2 SUT
11-25-2006, 07:46 PM
MINE - 2006 H2 SUT
