Old 11-29-2006, 01:19 AM
Default Re: PARTSGUY - NEED HELP PLEASE
Not understanding the Prime every time statement. Sure that isn't just the first time?
There is a one-way check valve between the unit and the reservoir that prevents fluid from going back into the reservoir, so how is the unit going dry? The unit, whether on or off, just allows the fluid to be pushed through from the pump.
I would understand if you run out of fluid it would require priming again.
Old 11-29-2006, 04:54 AM
dochummer's Avatar
That makes sense to me. But, when I called tech support they said that it's most likely fried because I didn't prime it...asked me to send it to them....unfortunately, it's an ebay purchase from over a year ago, so no warranty left on it....figured I'd install the extra one I bought and see what happens....
I sure do like the heated windshield on the wifes LR though....
'03 H2
Old 11-29-2006, 05:49 PM
partsguy partsguy is offline
Neil call me! lost your number! be back to work after 3:00.
Old 10-17-2007, 06:16 PM
btt- anyone else do the installation yet?
Where do you order from? I called the company, but no response.
I'd like to do the factory setup if I can't get the cheaper one.
Old 11-27-2007, 11:41 PM
Originally Posted by SUT NEIL
Latest update regarding HotShot heated windshield washer system:
I recently purchased a brand new in the box Microheat HotShot system on ebay (Item #220034844895) for $77.50 + $8.50 shipping - "Smokin Deal". This is a complete system including the heater unit, wiring, switch, and mounting bracket. The heater unit appears to be identical to the heater unit used in the 2007 Glacier Blue special edition H2. I could have simply installed the entire system as purchased but I want as close to a factory installation as possible. Accordingly, I also ordered the GM factory mounting bracket, two wiring harnesses, and switch from Partsguy - total cost for these items from him approximately $240. I'll do the install as soon as I receive these items. Hopefully it will work and look like the factory install.
BTT NEIL, ...looking for some feedback as I just ordered these parts.
Old 11-28-2007, 12:56 AM
mikejr's Avatar
mikejr mikejr is offline
I reviewed the manual in my 08 and it doesnt say anything about priming the system before hitting the button. I dont know if the factory system on the 08 is the hotshot system or not.
The system takes about 30 to 45 seconds and then starts a series of i think 4 blasts of heated fluid.
2009 H2 Silver Ice LE
Old 11-28-2007, 01:21 AM
tower's Avatar
tower tower is offline
He Jeff!
Long time no speak! Don't do it! You'll only make all the bastards who hate you happy! So, if I can distract you, I too am going to join the Wabasto crew. Is there any particular advantage to using the factory harnesses or switch vs buying it off e-ghey? Does it look any more "factory?" f so I'm in! Do you have any shots or drawings of the switch and is location? Thank you and Happy Holidays!
~ron
Old 11-30-2007, 11:31 PM
SUT NEIL SUT NEIL is offline
SUT NEIL is on a distinguished road
Sorry guys for not responding sooner. I've been away for awhile.
DO NOT ORDER ANY OF THE GM WIRING HARNESSES THAT I TRIED TO USE AND PREVIOUSLY POSTED THE PART NOS. FROM WHAT I RECALL THESE ITEMS CANNOT BE USED UNLESS YOU ALSO REPLACE THE ENTIRE DASH WIRING HARNESS. I used the GM mounting bracket and all items included with the Webasto Hot Shot unit. It looks pretty close to a factory installation. One caution... Do not purchase a Hot Shot unit that you integrate into the wiper system wiring. I think they refer to this unit as including the automatic mode. It has inherent problems that were a nightmare to figure out - that is if rhey even offer this model any more. Purchase a Hot Shot that does NOT have to be wired to the wiper system.
Hope this helps!
2005 SUT: Firemist Red/Ebony; LUX; Sunroof; Uplevel Chrome Pkg; NAV; Air Suspension; Remote Start; Superchip; Volant CAI & MAF; 2006 Chrome SE Wheels & Front Brushguard; Front & Rear Cameras & Park Sensors With Audible Alarms & Digital Displays; Custom Tiger Stripe Interior Panels & Steering Wheel By OEMDASH; Bassani SS Exhaust; Wet Okole Seat Covers; Defenderworx Chrome Billet Tow Loops & Side Air Vents; HotShot System
1970 Pontiac Trans AM
2000 Mercedes SL500 AMG Sport
2006 C280 4Matic
Old 12-02-2007, 09:22 AM
tower's Avatar
Just won ebay auction! $91 + $10 S&H = $101 total.
Sure could use photos for installation. Thanks!
Old 12-02-2007, 03:19 PM
mikejr's Avatar
T - here are some photos of the install under the hood and also the switch on the dash. The switch on the dash is a combo switch, the top part kills the interior lights when the door is opened, the center round one controls the dash lights and the lower 1/2 of the switch is the heated washer fluid switch and indicator light.
The under hood unit is mounted with a bracket on the drivers side of the washer tank. There are some pretty girthy wires running into the unit so it must draw quite a bit of juice.
Kinda hard to get a good shot where its located and all the other stuff in the engine bay. I guess I could rip out the engine and get you a few better photos...LOL
Hope these help!
Old 12-02-2007, 03:34 PM
tower's Avatar
Mikey. YOU RULE! That was just what I needed. Although I'm hoping someone with the LIMITED EDITION will post shots of their switch. (With the radical '08 change to the interior, there is no way for me to duplicate your switch set-up.) Thank you for your trouble. I look forward to the shots after you pull the motor.
Old 12-02-2007, 03:38 PM
mikejr's Avatar
T - I kinda figured my switch set up would not be useful to you due to the interior change. I dont know anyone with a LE to even look at one to see. Doesnt that guy that was promoting those ipod adapters have a blue LE? I seem to recall that.
Glad the under hood pics helped. Well guess I better get working on pulling the motor out...just hope i dont have any extra parts after I put it back in!
Old 12-02-2007, 06:29 PM
Thanks for those pics Mike. That helps for the underhood shot.
The LE switch just goes on the front facing AC Pannel. That one is easy. You can fuse the switch inside the drsd dash also.
I should have hte stuff next week and will post it up.
rep sent to Mike. Thanks!!!
Old 12-02-2007, 08:18 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
I installed the HotSHot a while ago and had problems with the unit working correctly if at all.
Neither myself or Webasto could figure it out. Webasto sent me a new unit and I had teh same problem!
Then it hit me it was a bad ground. I changed the ground wire and WEBASTO!! IT WORKED!!!
So when you install it make sure your using a solid ground.
BTW I'm not sure if Webasto changed the HotShots but when I installed mine a "Fix Kit" or "Bypass Kit" was needed for the H2.
A few years ago I did a write-up on the install for the Fix/Bypass Kit, you can see it by clicking below:
http://www.elcovaforums.com/forums/s...hlight=hotshot
Old 12-02-2007, 08:50 PM
tower's Avatar
Thank you, NJ. I already had your thread saved for later (very well done, BTW) I will wait until I receive my unit and then call Webasto/Microheat to see if I need the bypass kit. Can't wait!
Old 12-02-2007, 09:07 PM
mikejr's Avatar
Any time, glad I could help you guys out.
Old 12-03-2007, 02:41 AM
Hey guys back at you with some additional info:
1. To the best of my recollection, the Microheat Hot Shot unit (The black box that heats the fluid) is the exact same unit that GM uses. This box looks exactly the same as the one GM uses.
2. The switch, wiring harnesses, and mounting bracket provided by Microheat are different than the ones used by GM. I bought and used the GM mounting bracket with my Microheat Hot Shot unit. You cannot use the GM wiring harnesses located in the engine compartment unless you also replace your entire dash wiring harness - too much work and expense as far as I'm concerned.
3. The 2006 LE has the switch mounted on the drivers side of the dash below the AC vent. I used this space to mount my bluetooth phone setup so I mounted the HotShot switch on the center verticle dash piece in front of the shifter handle, to the far left side of the cigarette lighter & the 3 12v sockets. It fits and looks great in this spot which also enables you to hide the wire behind the dash without seeing it.
Hope this info is of value.
2006 C280 4Matic
Old 12-03-2007, 06:58 AM
tower's Avatar
Thank you Neil. Got photos?
Old 12-03-2007, 07:49 AM
tower's Avatar
Hey, all! Doing some searching around, I stumbled onto these threads which I think are very helpful! I love this site!
Link1
Link2
Link3
LE switch:
Aftermarket switch:
Old 12-04-2007, 03:10 AM
NJ H2's Avatar
I mounted the HotShot to the Firewall. It was very easy and it's been there for years with no problem. I have seen the pictures of the bracket that attaches by the Washer fluid container and that looks fine. IMO either way is good.
Here are some pictures I took tonight. Don't mind the dirt I haven't cleaned the engine compartment since my last day of wheeling and I'm not about to clean it for you ugly bastages
The last PIC shows where I grounded it.
