Old 12-04-2006, 02:49 PM
NewHummerGuy's Avatar
Default Can/Could this be done to an H2??
http://flashoffroad.com/hmmwv/AddCti/ctiHmmwv.htm
Just curious if this could be done or if it wouldnt even be possible.
I'm Gonna crazy you my body
Old 12-04-2006, 03:08 PM
ROADCAPT ROADCAPT is offline
ROADCAPT is on a distinguished road
Default Re: Can/Could this be done to an H2??
From your post I see ya might be hitting the beach and deflating your tires every once in a while. Used to run Hatteras alot. The CTS system wouid be nice but it is just something else to go wrong. If the spindles come with the kit as indicated you could only use them on the frt after some serious mods. Then how would ya do the back? We have solid axles unlike the H1 with 4 independant corners. I would just keep using the portable tank or comp. These 35" tires only need to go down to 8 or 10 psi to run in the sand and I have never thrown one easin back to a gas/air station.
Good topic though.
Be Safe
Old 12-04-2006, 03:13 PM
Thanks Capt. Just was reading some tech stuff with H1's and was wondering if this could be done. Didnt even think about the axels.
So I guess it could be done but at a high cost. Thanks again.
Old 12-04-2006, 03:23 PM
Yes it could be done, but at costs that would exceed the value of the vehicle.
Old 12-04-2006, 03:26 PM
Well then it sure as hell aint worth it
Old 12-04-2006, 05:05 PM
You could always buy a Power Tank. You can have all of your tires back to 40psi in under 5 minutes. The CO2 is safe also.
Old 12-04-2006, 06:22 PM
Agreed. You could possibly air back up faster with a Power Tank than you could with CTIS on a H1, especially in you install their valves in the wheels.
http://www.trailduty.com/product_inf...roducts_id=141
