12-06-2006, 05:53 AM
Re: Where the heck is my engine compartment light?
i forgot that i said i'll post pics a long time ago, been a little busy with school. mine didnt come with a magnet but if it did i would have used that, would be easier to move around. The tape i used (3m double sided) seems to be hoding up pretty good, but when you kind of pull on it or bump it with something it doesnt seem sturdy, like it can come off, but it hasnt yet.
I mounted it by the battery a little back, kind of over the brake fluid, not over it but a little to the side. Tried to put it so it doesnt hit anything.
Also didnt want to put it far forward on the hood, because when im shutting it its gona feel alot more downward force at the front than near the back, which can cauze it to pop off.
sorry for the huge delay in a picture, it always slips my mind. ill try and remember to take a pic with the phone tomorow or as soon as possible.
how big is the magnet that is used, does it seem sturdy? i might get a magnet and glue it to the light or something.
12-06-2006, 05:57 AM
oh and by the way 35 bucks shipped is a pretty good deal.
12-06-2006, 12:02 PM
Originally Posted by marin8703
i got one of these http://www.pfyc.com/pc/GN3007/VTUNDE...ood+Light.html .
Then i connected it directly to the battery (added fuse). Interupted the circuit with a pin switch mounted to the right of the radiator, over the driver head light. When the hood is opened the light goes on, when you close it the light goes off.
I might also put a manual switch in there to be able to turn the light off with the hood open during the day. Now that i think of it the light might have one built in, gotta check.
PFYC is a good place to purchase from. However, I got a kick out of the magnetic based light being sold on the C5 store. Sure would be hard to use the magnet to attach the light to a Corvette Fender....
12-06-2006, 01:02 PM
Advance auto has the clip to battery cigarette lighter adapter. $2.69 + the magnetic plug in light with draw cord $6.69 works modular when you need it. Keep mine in a container in the engine compartment for certain times
12-06-2006, 04:29 PM
I didnt receive it yet The guy said it has a magnet at the light base and also a suction cup as you can see in the pic of the item.
I will get thin outside 3m double sided tape and mount it on the hood around the same spot as marin8703.
If the tape doesnt hold up ther are spots on the hood were the metal is doubled up and might be screwed to.
I will probobly have it by the weekend.
12-10-2006, 04:20 PM
marin8703 I recieved my light .It has the suction cup
(F5 it will work on a vet or the H3 fenders )
and theres a magnet under the light .
I noticed that there are raised tabs on the bottom.(easy to cut off if needed)
Does yours have a flat surface? how did you mount the tape.
I need to pop the hood and find a nice mounting spot.
Not sure if Ill tape it or screw it.Im out of tape so I will need to pick some up.
Maybe on the top of the battery box if it fits then nut/bolt it from the underside of the box.(kinda like the compressor install.)
Pick of the bottom
12-10-2006, 04:49 PM
Possible mounting spot, using flush bolt heads from the bottom of the cover
12-10-2006, 04:52 PM
Another angle.
Any thoughts on this spot .
It would be firmly mounted.
I dont have time to put it in today and I will be needing some SS bolts/nuts/washers and a fuse.
12-11-2006, 12:17 AM
i used two pices of double sided tape (back to back) and cut it to fit between the weird tabs (seemed like ti would be a pain to cut those things off, hehe). Im still wondering why mine didnt have a magnet or suction cup, hehe, no biggie. that looks like a good place to mount it. im still trying to post a pic of mine but somehow im comming out retarded on this one. You ordered the thing got it and posted pics and i cant even take a pic yet  . Oh and that compressor setup is sweet as hell, i want to do that too, they should make that optional from the factory, great job.
12-11-2006, 12:18 AM
also the H3 sticker on the compresor is a nice touch, looks OEM!!!
12-11-2006, 02:36 AM
Its acually Jp's idea  I did think of the sticker
link
http://www.elcovaforums.com/forums/s...ead.php?t=5167
How come you didnt get a magnet or suction cup
Im going with the battery cover mount,handy spot EZ install can put the loght anywhere anytime.
I picked up some 3/4 inch bolts with small screw heads and a fuse today.
I will probably install it next weekend
12-11-2006, 03:56 AM
I took the retractable unit with mercury switch out of my 87 Jeep Cherokee and mounted it on the aft portion of the hood. The height is advantageous - it lights the entire compartment without blinding you. I'll grab some pics tomorrow and post.
12-17-2006, 08:06 PM
I mounted the light  .On top off the battery cover seems to be a nice firm mounting surface .I mounted it with 3 flat top bolts(painted black) with washers from the underside of the cover.
I used a dab of silicone to seal it and lock tight on the nut.
A lesson learned, when hooking the battery back up make sure you disable the auto start or it starts up unexpectedly
There is a warning sticker above the radiator
12-17-2006, 08:10 PM
Very handy, light cord is 20 feet long.
Unplugs easy for battery cover removal.
I also measured the factory battery
7 inches high
9 inched long
6.75 inches wide
Do they make a optimum battery in that size?
Im running out of room under the hood
side view
