Old 01-02-2007, 06:18 AM
Default Re: TGL's on-board compressor
gotta have these!!!
Old 01-02-2007, 06:19 AM
Old 01-02-2007, 06:20 AM
Tarrrraaa!!!!!!!
Old 01-02-2007, 06:21 AM
When not in use....
Old 01-02-2007, 06:30 AM
That's it!!!!
Old 01-02-2007, 07:18 AM
dochummer's Avatar
Looks great! What are the specs on the compressor? Total cost?
'03 H2
Old 01-02-2007, 07:23 AM
I got it as a christmas gift...
http://www.hummersolutions.com/produ...roducts_id/720
Old 01-02-2007, 07:26 AM
The 400P can air up a 35" x 12.5" tire from 15 to 30 PSI in about 1.25 minutes, and air down the same tire from 30 to 15 PSI in about 2.75 minutes using the versatile 35 ft. air down hose.
Old 01-02-2007, 07:32 AM
Nice.
I'd recommend using rubber grommets on all of the holes where the cable passes through metal.
Old 01-02-2007, 07:35 AM
Nice.
Sweet,....will do.
Old 01-02-2007, 08:11 AM
raptorman53's Avatar
nice install
06 Adv. nuff said
Old 01-02-2007, 11:54 AM
Nice, great location. Do you get any vibration from the compressor while driving?
I totally agree with DRTY, add some rubber to some of those locations, and I'm sure there is a fuse at the start of the B+ cable.
(Next time write me, there is a way to go from front to back without cutting any holes in the vehicle, except at the trim panel.)
Old 01-02-2007, 01:50 PM
BACKNBLACK's Avatar
BACKNBLACK BACKNBLACK is offline
BACKNBLACK is off the scale
TGL Looks good. To air down I would buy the stauns they work great and can be set to a psi you want and can be put on all 4 tires at the same time.
http://cgi.ebay.com/Set-of-6-4WD-TRAILER-Staun-Tyre-DEFLATORS-for-OFFROAD_W0QQitemZ220064158458QQihZ012QQcategoryZ30 862QQssPageNameZWDVWQQrdZ1QQcmdZViewItem?hash=item 220064158458
F5, what might that path be? Please enlighten us :-) I assume through the firewall and under trim and carpet?
CURRENT HUMMER:
Number# 11 2007 H3x Desert Orange
SOLD BUT NOT FORGOTTON
1995 H1 350 HT GAS Black
2001 H1 Open Top Black
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
2008 H2 Black/Sedona
2009 H3T Alpha Solar Flare
Old 01-02-2007, 05:45 PM
Actually, the path is just inside the rear luggage compartment trim panel; in the rear corner. Fish the wire down, then through a square hole, and then down under the vehicle. Then run the wire over to the driver's side (or you can find a hole on the driver's side too), and follow the routing of the rear trailer harness wiring. This goes up into the engine compartment, right behind the battery.
Or you could just follow and tie strap on top of the frame rails, and around body mounts.
Old 01-02-2007, 05:50 PM
Very cool!
Old 01-02-2007, 06:02 PM
Klint's Avatar
Klint Klint is offline
what is it's max PSI? Could you fill a Air tank with it?
Klint T.
2007 Black Lux, Blinged out
Old 01-02-2007, 06:08 PM
Klint's Avatar
I need to find a dry place that I can almost sound proof but still allow air in that I can put a 200PSI compressor that will fill my 3GAL air tank for my train horns lol any Ideas?
Klint T.
Nice job... How long did it take?
RYD
Old 01-02-2007, 06:20 PM
Not sure yet, but I know it can air up a 35" x 12.5" tire from 15 to 30 PSI in about 1.25 minutes....
Old 01-02-2007, 06:22 PM
RYD
How long?, I'm guessing a good 2-3 hours.
