Old 01-09-2007, 12:26 AM
Default Darwin Awards for 2006
They are finally out again.
In case you don't know it's an annual honor given to the person who did the gene pool the biggest service by killing themselves in the most extraordinarily stupid way.
Last year's winner was the fellow who was killed by a Coke machine which toppled over on top of him as he was attempting to tip a free soda out of it.
And the nominees this year, in reverse order, are:
7. A young Canadian man, searching for a way of getting drunk cheaply because he had no money with which to buy alcohol, mixed gasoline with milk.
Not surprisingly, this concoction made him ill, and he vomited into the fireplace in his house. The resulting explosion and fire burned his house down, killing both him and his sister.
6. A 34-year-old white male found dead in the basement of his home died of suffocation, according to police. He was a approximately 6' 2" tall and weighed 225 pounds. He was wearing a pleated skirt, white bra, black and white saddle shoes, and a woman's wig. It appeared that he was trying to create a schoolgirl's uniform look. He was also wearing a military gas mask that had the filter canister removed and a rubber hose attached in its place. The other end of the hose was connected to one end of a hollow tube approximately. 30" long and 3" in diameter. The tube's other end was, for reasons unknown, inserted into his rectum and was the cause of his suffocation.
Police found the task of explaining the circumstances of his death to his family very awkward.
5. Three Brazilian men were flying in a light aircraft at low altitude when another plane approached. It appears that they decided to moon the occupants of the other plane, but lost control of their own aircraft and crashed.
They were all found dead in the wreckage with their pants around their ankles.
4. A 22-year-old, man was found dead after he tried to use octopus straps to bungee jump off a 70 foot railroad trestle. Fairfax County police said Eric Barcia, a fast-food worker, taped a bunch of these straps together, wrapped one end around one foot, anchored the other end to the trestle at Lake Accotink Park, jumped and hit the pavement. Warren Carmichael, a police spokesman, said investigators think Barcia was alone because his car was found nearby. "The length of the cord that he assembled was greater than the distance between the trestle and the ground" Carmichael said. Police say the apparent cause of death was "Major trauma."
3. A man in Alabama died from rattlesnake bites. It seems that he and a friend were playing a game of catch, using the rattlesnake as a ball. The friend, no doubt a future Darwin Awards candidate, was hospitalized.
2. Employees in a medium sized warehouse in west Texas noticed the smell of a gas leak. Sensibly, management evacuated the building, extinguishing all potential sources of ignition; lights, power, etc. After the building had been evacuated, two technicians from the gas company were dispatched.
Upon entering the building, they found they had difficulty navigating in the dark. To their frustration, none of the lights worked.
Witnesses later described the sight of one of the technicians reaching into his pocket and retrieving an object that resembled a cigarette lighter. Upon operation of the lighter-like object, the gas in the warehouse exploded, sending pieces of it up to three miles away. Nothing was found of the technicians, but the lighter was virtually untouched by the explosion. The technician suspected of causing the blast had never been thought of as 'bright' by his peers.
AND THE WINNER.....(ouch....)
1. Based on a bet by the other members of his threesome, Everitt Sanchez tried to wash his own "balls" in a ball washer at the local golf course. Proving once again that beer and testosterone are a bad mix, Sanchez managed to straddle the ball washer and dangle his balls in the machine.
Much to his dismay, one of his buddies upped the ante by spinning the crank on the machine with Sanchez's balls in place, thus wedging them solidly in the mechanism. Sanchez, who immediately passed his threshold of pain, collapsed and tumbled from his perch. Unfortunately for him, the height of the ball washer was more than a foot higher off the ground than his testicles are in a normal stance, and his balls were the weakest link. Sanchez's balls ripped open during the fall, and one testicle was plucked from him forever and remained in the ball washer, while the other testicle was compressed and flattened as it was pulled between the housing of the washer, and the rotating machinery inside.
To add insult to injury, Sanchez broke a new $300.00 driver that he had just purchased from the pro shop , and was using to balance himself . Sanchez was rushed to the hospital for surgery, and the remaining threesome was asked to leave the course.
Note: This last one wouldn't normally count, because the idiot didn't die. But because he cannot reproduce as a result of his qualifying act of stupidity, we have allowed it
Old 01-09-2007, 03:32 AM
3Hummer's Avatar
3Hummer 3Hummer is offline
Default Re: Darwin Awards for 2006
ouch!!! I went through soo much pain just reading the last one. I cant beileve anyone in there right mind would take up a dare like that!
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
Old 01-09-2007, 04:23 AM
These aren't the right awards...
Number one was from 1997:
http://www.darwinawards.com/darwin/darwin1997-05.html
2006's winners are here from darwinawards.com/:
http://www.dailykos.com/storyonly/2007/1/3/174427/2311
See also: http://darwinawards.com/darwin/darwin2006.html
2006 RUNNER UP: Copper Kite Darwin Award -- Confirmed
"One string short of a kite."
(19 March 2006, Belize) Benjamin Franklin reputedly flew his kite
in a lightning storm, going on to discover that lightning equals
electricity. However, certain precautions must be taken to avoid
sudden electrocution. Kennon, 26, replicated the conditions of
Ben Franklin's experiment, but without Ben's sensible safety
precautions. Dennon was flying a kite with a short string that
he had extended with a length of thin copper wire.
The copper made contact with a high-tension line, sending a bolt
of electrical lightning towards the man. Just bad luck?
Kennon's father told listeners his son was an electrician, and
"should have known better." Kennon is survived by his parents,
six sisters, and five brothers.
Vote!
2006 RUNNER UP: Hammer of Doom Darwin Award -- Confirmed
August brought us a winner from Brazil, who tried to disassemble
a Rocket Propelled Grenade (RPG) by driving back and forth over
it with a car. This technique was ineffective, so he escalated to
pounding the RPG with a sledgehammer. The second try worked--in
a sense. The explosion proved fatal to one man, six cars, and
the repair shop wherein the efforts took place.
14 more RPG grenades were found in a car parked nearby. Police
believe the ammunition was being scavenged to sell as scrap
metal. If it wasn't scrap then, it certainly is now!
Vote!
And the 2006 DARWIN AWARD Winner is...
HIGH ON LIFE: "Take a deep breath..."
(3 June 2006, Florida) Two more candidates have thrown themselves
into the running for a Darwin Award. The feet of Jason and Sara,
both 21, were found protruding from a deflated, huge helium
advertising balloon. Jason was a college student, and Sara
attended community college, but apparently their education had
glossed over the importance of oxygen.
When one breathes helium, the lack of oxygen in the bloodstream
causes a rapid loss of consciousness. Some euthanasia experts
advocate the use of helium to painlessly end one's life.
The pair pulled down the 8' balloon, and climbed inside. Their
last words consisted of high-pitched, incoherent giggling as they
slowly passed out and passed into the hereafter.
Sheriff's deputies said the two were not victims of foul play. No
drugs or alcohol were found. The medical examiner reported that
helium inhalation was a significant factor in their deaths. A
family member said "Sara was mischievous, to be honest. She liked
fun and it cost her."
Old 01-09-2007, 06:00 AM
westhillsat's Avatar
Crazy people
Old 01-09-2007, 07:49 AM
I just checked myself. All's good.
