Old 12-20-2005, 09:54 PM
Wow, Stacy. That's a small truck.
Old 12-20-2005, 11:14 PM
Bolts21 Bolts21 is offline
Bolts21 is off the scale
thanks Devil, never had any problems with anything else? If I never plan on lifting it, would you reccomend 35's or 7's?
Old 12-21-2005, 11:24 PM
devilsfan's Avatar
Wow, Stacy. That's a small truck. </div></BLOCKQUOTE>
Better?
Bolts - Other than the bad alignment, I had zero issues running 37s with all else stock. The height difference was very noticeable - a lot of non-H2 owners would come up to me and ask if it was lifted. But the nice thing is, the handling was the same and none of your warranty was voided. You MIGHT get some rubbing at the top of the wells if you go over something like a speed bump, but it's not going to hurt anything.
I've been VERY pleased with the MTRs. If you're not taking it off-road, I would highly recommend these tires - I've put about 20,000 miles on them and they show almost no wear at all. They're one of the harder compound tires out there.
Stacy
Old 12-22-2005, 05:21 PM
37s, no lift. Offset wheels eliminated the rubbing.
Old 12-22-2005, 06:03 PM
Alec, that's a nice winch bumper. Where'd you get it? And I thought you had the rear of your truck lifted about 10"s when you were in Moab.
Much better, Stacy.
Adam, that's a nice pic, brother.
Old 01-11-2007, 09:29 AM
JDLarue's Avatar
JDLarue JDLarue is offline
JDLarue is on a distinguished road
Default Re: Help...........37" or 35", with no lift?
37x13.50x17 Toyo M/T's on stock rims with no lift on an 03 H2. Only slight rubbing when making tight turns. Just took off some BFG muds and they were WAY louder than the Toyo's on the road.
2003 H2 Lux series, Pewter (I know...non-color) Airaid intake system, Granitelli MAF, Hypertech III programmer, sun roof, brush guard, a little billet bling, air suspension, 37x13.5x17 Toyo M/T's on stock chrome rims, 06 mirrors, like to get a 6" Fabtech lift but couldn't get it in the garage, other than that...pretty much stock.
Old 01-11-2007, 04:28 PM
This thread was dead for like 13 months. Weird.
Old 01-11-2007, 06:34 PM
MarineHawk's Avatar
Adam: What kind of wheels do you have and what is the backspacing? I'm looking for black wheels with 4.5" BS.
Thanks in advance.
Old 01-11-2007, 07:28 PM
Thanks in advance.
Rockcrawler Series 97. They have 3.5".
Old 01-12-2007, 07:48 AM
Longhorn's Avatar
Longhorn Longhorn is offline
Longhorn is off the scale
37" BFG MTs on stock rims! No lift.
I bought my 2nd set 2 weeks ago. I got ~35K miles out of the last set with a lot of wheeling trips.
They balance easily, they're fairly quiet and they perform well in a wide range of conditions. I have heard they suck in snow, but we don't get that in Central Texas.
Old 01-12-2007, 01:01 PM
MarineHawk's Avatar
Thanks. Are you happy with them?
It looks like they also come in 4.5" BS: http://www.4wheelparts.com/4wp/products/productLine.asp?cat=WHE&prodline=3204&catName=&man =TECH
I assume I would want the 9" ones, right?
I've got the 37" X 13" (name says 12.5", but specs say 13.1") Cooper STTs.
Something like?:
Rock Crawler Series 97
Size: 17 X 9 Bolt Pattern: 8-6.5
Back Spacing: 4.5 Finish: Black Painted
PCW97-7981
Old 01-15-2007, 09:28 PM
Talking Re: Help...........37" or 35", with no lift?
well i got the front leveling kit and 5000 miles and no problems,
i'm running 37x12.50xR17 Procomp Extreme a/t's on the stock wheels and even with the leveling kit, i have a slight rub at full turn. i would go with the 37" and crank the torsion keys a bit and you should be fine, just go with a 12.5 wide tire.
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
Old 01-22-2007, 11:27 PM
Diceman's Avatar
Diceman Diceman is offline
Diceman is on a distinguished road
20" RIms with 37" Tires, no Lift and no problems!
