01-16-2007, 06:23 AM
Crap, oil pan gasket is leaking
Can the dealer remove pan and replace the gasket from underneath without pulling block? I sure hope so...
01-16-2007, 08:01 AM
Re: Crap, oil pan gasket is leaking
Oil pan gasket??? Uh... you could fix it yourself. have you ever been under your rig?
All you do is drop the oil pan (drain the oil first), clean the surfaces, install new gasket and replace pan.
01-16-2007, 04:12 PM
is under warranty
will probably wait until time to change oil as I just changed it with Mobil1 and I am sure dealer will put dino back in there when they do it.
01-16-2007, 11:07 PM
Don't forget you need an alignment!
01-17-2007, 12:30 AM
Don't let the dealer rape you on a new oil pan. Go with a Caphalon pan and do it yourself.
01-17-2007, 03:43 AM
I thought I read that the T-Fal pans were better than those....
2009 H2 Silver Ice LE
