Old 01-18-2007, 04:20 AM
working Hummer's Avatar
Default winch
Hey, what is the difference between the Warn 9.5ti winch and the 9.5ti winch for Hummer that would constitute $200 more?
Old 01-18-2007, 04:33 AM
MarineHawk's Avatar
Default Re: winch
Perhaps the latter has an "H" painted on it?
Old 01-18-2007, 04:50 AM
tomp's Avatar
tomp tomp is offline
Default Re: winch
The one hummer sells says Hummer on it, has veritcal hole pre-drilled for mounting on the front receiver, is only 9000 pound rated.
Direct from Warn you get 9500 rating, thermo feedback monitoring on remote with flashlight.
Which winch would you like to have on your H2:
this nicer one for less money:
Old 01-18-2007, 04:51 AM
tomp's Avatar
Default Re: winch
or the pricey lesser model with Hummer logo (that is on top of winch and can't be seen from the front) for $200 more:
Old 01-18-2007, 04:52 AM
tomp's Avatar
Default Re: winch
BTW, the one from Hummer does not come with the roller fairlead as shown in the bottom pic.
Notice the first pic has newer casing with better water protection and heatsink etc...
Old 01-18-2007, 04:56 AM
tomp's Avatar
Default Re: winch
It cost me $5 to have the vertical hole drilled
Old 01-18-2007, 06:18 AM
DIRTYVEGAS's Avatar
DIRTYVEGAS DIRTYVEGAS is offline
DIRTYVEGAS is on a distinguished road
Default Re: winch
Is it worth getting the model that you can remove and use in the rear receiver? $400 more
Old 01-18-2007, 02:07 PM
Default Re: winch
This winch is not from hummer, if you go to GoWarn or any other winch site it has a 9.5ti, scroll down a little and it will say 9.5ti for Hummer but it will cost at least $200 more. Is it the same winch but just a vertical hole drilled in it? I mean hell, I'll drill a hole in it for $200, but is that all it is?. I'm getting the one you put in the hitch that's removable but why is the one made especially for Hummer (it says) more expensive?
Old 01-18-2007, 04:06 PM
Vettster Vettster is offline
Default Re: winch
I'm pissed!
Mine doesn't say Hummer on it.
