09-02-2004, 08:01 PM
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Service Information</TITLE>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="Microsoft FrontPage 5.0" name=GENERATOR></HEAD>
<BODY bgColor=#ffffff>
<FORM name=topNavForm action=/servlets/CellHandler>
<TABLE width="100%" align=center>
<TBODY>
<TR>
<TD width="25%" slign="LEFT"></TD>
<TD align=middle width="50%">Document ID# 1546260
2003 HUMMER
H2 </TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE>
<HR>
</FORM>
<H1>Adm Msg - 2003, 2004 HUMMER H2 Rear Air Suspension Compressor Service Part
Change #HUS20040023 - (08/23/2004)</H1>2003, 2004 HUMMER H2 Rear Air Suspension
Compressor Service Part Change
</P>
The single rear air suspension compressor used on the 2003 and 2004 HUMMER H2
has been discontinued and is replaced with the dual air compressor used on the
2005 model. The dual compressor can be used to service the prior model vehicles.
The Service Parts Catalog will direct you to order the new dual compressor,
P/N89060581 and indicates that you will also need inflator pipe,
P/N15117941 and intake and exhaust pipe assembly, P/N15117942. Refer
to the 2005 installation instructions foundin SI Document1457105.</P>
</P>
<TABLE width="100%">
<TBODY>
<TR>
<TD align=left width=778><FONT size=1>GM bulletins are intended for use by
professional technicians, NOT a "do-it-yourselfer". They are written
to inform these technicians of conditions that may occur on some vehicles,
or to provide information that could assist in the proper service of a
vehicle. Properly trained technicians have the equipment, tools,
safety instructions, and know-how to do a job properly and safely.
If a condition is described, DO NOT assume that the bulletin applies to
your vehicle, or that your vehicle will have that condition. See
your GM dealer for information on whether your vehicle may benefit from
the information.
</FONT></TD>
<TD align=middle width=42></TD>
<TD align=middle width=167><FONT size=2>WE SUPPORT VOLUNTARY TECHNICIAN
CERTIFICATION
</FONT></TD></TR></TBODY></TABLE>
<P align=center>© Copyright General Motors Corporation. All Rights
Reserved. </P>
<FORM name=bottomNavForm>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2 </TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE></FORM></BODY></HTML>
<TBODY>
<TR>
2003 HUMMER
H2 </TD>
<HR>
</FORM>
</P>
</P>
<TBODY>
<TR>
the information.
</FONT></TD>
CERTIFICATION
Reserved. </P>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2 </TD>
<TBODY>
<TR>
2003 HUMMER
H2 </TD>
<HR>
</FORM>
</P>
</P>
<TBODY>
<TR>
the information.
</FONT></TD>
CERTIFICATION
Reserved. </P>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2 </TD>
09-14-2004, 11:48 PM
Question on Rear Air.
Recently my compressor was not functioning.
My rear began to sag after about 5 days.
Do they slowly leak down??? Or does mine have a slow leak.
03-19-2005, 08:55 PM
Doc, some good exercise should take care of that sagging rear.
What's the difference between the two air compressors?
'03 H2
03-19-2005, 10:54 PM
Yeah, I would recommend bicycling! Sorry, you really left yourself open with that remark.
Seriously, you may have a leak, but probably not given the rate of air loss. Air does manage to seep (osmosis) through rubber, butyl & latex barriers at a slow rate. That’s why bicycle tires will always go flat over time, even without any leak. That's also why your airbags will inflate "on their own" every once in a while. I am clueless on the dual compressor issue, but I would bet Klaus will tell you more soon.
03-21-2005, 02:31 AM
I wonder if I can get my dealer to replace mine under warranty. Really, it is broken... promise.
Klaus, is there any benefit to using the dual air compressor model?
03-21-2005, 02:50 AM
I don't know, Ken... I haven't had any problem with the compressor on my truck.
I'm sure one of the dealership techs here on the forum could tell us more.
03-21-2005, 01:31 PM
I think we discussed this before but I don't remember any of the details. Anyway, if you think your compressor is even close to death, get it done under warranty. It's about $1000 just for the new compressor itself.
03-31-2005, 01:48 AM
anything new on this subject ?
03-31-2005, 02:01 AM
Hummertech... do you have any opinion on this? I have an issue with the adventure series air system that only manifests at temps below 45F. At 45F and lower I get a persistent knock (sounds like a solenoid tripping) from the rear, I'm guessing dehydrator or an air system valve..dealer has twice told me that they could not determine/duplicate the fault.
03 Yellow Adventure
97 SS Camaro SLP Build # 2919
