02-04-2007, 10:59 PM
Re: H2 camera installation
NICSH
02-07-2007, 12:04 AM
Thanks, When are you going to do yours?
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
02-07-2007, 02:00 AM
All you need to do is put in one normal 12v relay.
The connections are:
85 negative
86 12v + that gets hot when you flip a switch
87 12v +
87a 12v + that gets hot when you put it in reverse
30 goes to the 12v + of the screen (normally 87a and 30 would be the same wire connected together)
Under normal circumstances the reverse light will turn on the screen. If you want to see it while driving, flip the switch and it will come on but not backfeed to the reverse lights.
It works like a charm, I have it wired up this way. I have the same camera but with the little screen that attaches to the windshield. The switch and relay is inside the overhead console. No problem.
02-07-2007, 08:20 AM
2005 SUT: Firemist Red/Ebony; LUX; Sunroof; Uplevel Chrome Pkg; NAV; Air Suspension; Remote Start; Superchip; Volant CAI & MAF; 2006 Chrome SE Wheels & Front Brushguard; Front & Rear Cameras & Park Sensors With Audible Alarms & Digital Displays; Custom Tiger Stripe Interior Panels & Steering Wheel By OEMDASH; Bassani SS Exhaust; Wet Okole Seat Covers; Defenderworx Chrome Billet Tow Loops & Side Air Vents; HotShot System
1970 Pontiac Trans AM
2000 Mercedes SL500 AMG Sport
2006 C280 4Matic
02-12-2007, 03:43 PM
i was in the process of using that pac adapter for the stock headunit for a similar setup but couldn't get it to ork properly. Did you install it yourself?
I ask because its kinda tricky, i guess, however, not very difficult. I could get the image to return back to normal with the adapter. The screen would shift, blink, roll around on the screen, thus not allowing the stock nav functions to be utilized. I'm not sure if it was defective but i just returned it and considered that its just a "ok" product.
got any feedback on that unit? thanks!
02-12-2007, 04:25 PM
I installed mine last year and worked fine and have not read of anyone having problems.....
02-13-2007, 12:12 AM
well, i guess im the only idiot that got the install wrong!!
i haven't tried after the initial attempt, however, i was at it for about 6-8hrs and i couldn't get it to work. Maybe it was a bad unit, but i gave up on it...
im thinkin of going to a pioneer Z1 and see what i can with that..
02-13-2007, 09:57 PM
it is a very easy install for the pac unit i actually had to install it twice after my first head unit took a dive. i removed it and sent it back got the new unit and installed it in there and no problems. the directions are pretty straight forward.
on the other hand the avic-z1 is also a nice unit but you will have to bypass some things if you want the unit to play when not in park.
check out this site
http://www.avic411.com
you can find some great info on all the pioneer units
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
